Old 08-09-2017, 10:44 AM   #1
LostCause1979
Default Ocean MK18s
Im trying to figure out which tire size i can run but cant seem to find anything. I have 82 242 wells already rolled. Ive seen i can run 215 35 and someone said 225 40 if they were rolled. Was wondering if anyone knows if i can go any wider on a 40 series or is that the limit?
LostCause1979 is offline   Reply With Quote
Old 08-09-2017, 02:06 PM   #2
Can play the blues
225 is probably the widest you can go without more changes. You can check out in maybe in showroom threads on widening the rear wheel arches. I know with the rear arches rolled you can fit a 225/50-15 so a 40 series being shorter should also fit. The 50 series tire is closer to stock height with a 15 inch wheel.
1993 245 Classic, 417k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47.
Old 08-09-2017, 03:00 PM   #3
Tuff240
240 Ninja
Tuff240's Avatar
Depends on a few factors. Ride height, offset and how much you roll the lips. With out rubbing, 245's are the largest you can fit, but it takes a perfect combination of offset and rolled lips.
You will need an adjustable panhard bar also.
You have mk18's in the USA? Most likely the only set here if you do.
18x8&9's with 245/40-18's all around. Original paint car. No rubbing:
-Patrick
Old 08-09-2017, 05:32 PM   #4
Can play the blues
Looks excellent Pat!
