Old 08-02-2017, 02:06 AM   #1
VolvoPrince
Default 98 V70R P1505 and high idle
Alright... Title says it all. New PCV system. All new vacuum hoses, turbo hoses, idle control valve, MAF, throttle body gasket (and cleaned). It idles fine when cold around 900RPM, then goes up to about 13-1400 when warm. Temperature gauge reads fine and rises normally. Lately it has now been surging at stop lights and it's driving me nuts. The CEL is also limiting boost when it comes on... Not cool. What else do I check?! I'm loosing it.
1984 245 (400K Miles and counting)
1998 V70R AWD
VolvoPrince is offline   Reply With Quote
Old 08-02-2017, 08:39 AM   #2
doucheNozzle
doucheNozzle's Avatar
Have you looked up that code?
'99 V70 NAA - So Slow
'04 V70 T5A - Feels Fast
Old 08-02-2017, 12:11 PM   #3
VolvoPrince
Idle control valve code, but I've already replaced it with 3 separate units.
Old 08-02-2017, 01:46 PM   #4
doucheNozzle
Coulda fooled me. Didn't say that in op.
Have you smoke tested or pressure tested for vacuum leaks?
Old 08-02-2017, 02:33 PM   #5
Matt86
Matt86's Avatar
Sounds like you've got a vacuum leak somewhere, loose boost hose or something.
1998 V70R
1989 245 DL
Matt86 is offline   Reply With Quote
Old 08-03-2017, 12:25 AM   #6
VolvoPrince
Haven't smoke tested it but I have checked EVERY vacuum hose possible and replaced it. I've used the carburetor cleaner method of checking for leaks. I'm starting to wonder if it's a wiring issue with the IAC.
Old 08-03-2017, 11:13 AM   #7
Maybe try cleaning the throttle body and resetting the computer.
Old 08-03-2017, 11:37 AM   #8
VolvoPrince
Already tried :(
Old 08-03-2017, 03:11 PM   #9
If I had it at the shop I would first look up common causes of the code on software. Then probably do a 3 minute smoke test.
Old 08-09-2017, 10:12 AM   #10
doucheNozzle
Then do that.
