Old 08-07-2017, 04:12 AM   #1
DaBossk
DaBossk's Avatar
Default installed camshaft wrong?
Hey guys... I'm trying to install my IPD performance turbo cam on my 1991 volvo 780 turbo I got in the mail a while back...
So I just took the old one out and installed the new one but when I went to turn over the camshaft with my wrench it locks up after the 3rd rotation! what gives?
It feels like the valves are hitting the pistons but these engines are non interference unless the head is shaved Ive heard??
Any ideas? please help!!!!
Do you even boost?
DaBossk is offline   Reply With Quote
Old 08-07-2017, 04:22 AM   #2
DaBossk
DaBossk's Avatar
update***
if I turn the crank to a different position the cam spins like it should! wth....
I'm thinking my engine is now interference from someone shaving the head.
should I throw the t-belt on and start the engine?
Old 08-07-2017, 04:23 AM   #3
Pro Sneaker Peddler
Evidently it's an interference motor. Are you trying to spin the cam independently of thr rest of the system?
Also, time it so the intake lobe opens #1 intake valve 1mm at tdc (with the #1 lobes pointing down obv.). Don't trust your cam timing mark.
Old 08-07-2017, 04:34 AM   #4
DaBossk
DaBossk's Avatar
yes to your first question. guess I should attach the belt and see if the engine turns over smoothly together.
And okay I will follow your advice making sure the #1 intake valve is open when the piston is @ tdc. Just out of curiosity tho... why shouldn't I trust my cam timing?
Old 08-07-2017, 04:43 AM   #5
DaBossk
DaBossk's Avatar
http://forums.turbobricks.com/showthread.php?t=138951
well I guess the ipd turbo cam makes it an interference engine!
whod've thought
Old 08-07-2017, 04:55 AM   #6
Pro Sneaker Peddler
Because the timing marks don't tale into account manufacturing variances in the engine, and the cam dowel is hardly ever at tdc with an aftermarket cam.
Anyway, start with -4° at the cam gear. It goes against forum lore but that's what it worked put at in my motor and Nathaninwa's dyno testing seems to corroborate. Just measure lift and call it good.
Old 08-07-2017, 05:04 AM   #7
DaBossk
DaBossk's Avatar
Okay thank you! I'm gonna work on it some more when I wake up
Old 08-07-2017, 11:13 AM   #8
Jimmy E. James
You can't shave enough off a head to make it an interference engine (well, guess you could but then you couldn't use the head)
Hard for me to believe that any cam for a red block, THAT radical, would be a good/smart thing for STOCK springs and followers to let things go that far?
I'd re-think it (unless you've had the head (valves and springs) re-worked also)
Jimmy E. James is offline   Reply With Quote
Old 08-07-2017, 11:15 AM   #9
And rent a shim kit while you're at it so it runs right.
how psi a stock can support?
Old 08-07-2017, 11:16 AM   #10
esmth
dirty swede
esmth's Avatar
I thought it was pretty well known that aggressive cams make the b230 interference
1991 244 +T LH2.4 m46 281k miles with B cam & STS cam gear adv 4*, 954 fuel & 207 ezk tuned with Ostrich, 350cc EV6 white injectors, 2.5" exhaust w/ magnaflow straight-through, SLC free wideband
Old 08-07-2017, 11:30 AM   #11
Jimmy E. James
Not everyone's an expert like you
Old 08-07-2017, 12:20 PM   #12
Tuff240
240 Ninja
Tuff240's Avatar
Quit "guessing", because you can shave a head that much and you can still use it.
-Patrick
Tuff240 is online now   Reply With Quote
Old 08-07-2017, 12:25 PM   #13
Tuff240
240 Ninja
Tuff240's Avatar
OP, guess what, if you put the timing belt on like it's supposed to be, your motor is no longer an interference motor. You only need to worry about that if you don't plan on doing any maintenance and just driving it until the timing belt breaks.
Old 08-07-2017, 01:09 PM   #14
Pro Sneaker Peddler
Go jerk each other off in private
Old 08-07-2017, 01:29 PM   #15
Jimmy E. James
You cut a ****ing head to the point that it's an interference engine and the head is a ****ing doorstop
No guessing to it dick breath
Old 08-07-2017, 01:44 PM   #16
gsellstr
gsellstr's Avatar
I would see your point if you cut the head .060" and put an M cam in it with the pathetic lift it has, but if you cut the head and still have a cam with any kind of lift, yeah, it'll still be usable AND be interference. If you have .030" from valve to piston on a bone stock setup (SWAG, varies with cam obviously), you trim .035" off the head, yeah, it's interference. If you trim off .020" (min-spec on the 530) and go from a stock head gasket at .049" compressed to a tight squish gasket at .030", then it's interference, but the head sure as hell ain't a door stop.
IPD cam in mine right now, head was trimmed .010" (still .010" above min-spec), block was decked .005" to get desired piston height, .035" cometic, mine is no doubt interference.
RIP
74 144 B20
90 745Ti
Old 08-07-2017, 01:55 PM   #17
Tuff240
240 Ninja
Tuff240's Avatar
Oh yeah? How many have you cut that much? Obviously zero, because you would know it's possible and other than the very high compression ratio that you must compensate for, does work.
Not only have I done it, but I've raced (not actually drove, just pit crew) that same head in a 24hr long endurance race. We also tried angle cutting just to experiment. Nothing really ever came of it, but the point is, we tried and messed around more than most. You see, when you have a head surfacing machine in your shop, you get to do things like experiment and play around. A lot of things don't work out, but even in failures there is a lot to be learned. Much better than reading some stuff on the internet and proclaiming you know what you are talking about.
Old 08-07-2017, 02:00 PM   #18
KeizerBrickGuy
KeizerBrickGuy's Avatar
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 08-07-2017, 02:03 PM   #19
Jimmy E. James
I was working on Volvos (and every other make and model) when you were still sucking your mama's tit
Old 08-07-2017, 02:06 PM   #20
Tuff240
240 Ninja
Tuff240's Avatar
So you are a slow learner?
Old 08-07-2017, 02:17 PM   #21
2manyturbos
Knock it off. You don't need to insult people here to interject your "opinion" into a thread.
Old 08-07-2017, 02:19 PM   #22
Jimmy E. James
I agree - but it works both ways (listening to what people have to say)
Parts counter guys have never been known for being good listeners - mainly just for being funny
Old 08-07-2017, 02:21 PM   #23
esmth
dirty swede
esmth's Avatar
Pretty sure IPD's website or one of the various tech articles about the cam covered this. I cannot find it now. Sorry for triggering you.
Old 08-07-2017, 02:25 PM   #24
Jimmy E. James
Just popped off at the assumption was all
We're good if you're good
Old 08-07-2017, 02:27 PM   #25
Tuff240
240 Ninja
Tuff240's Avatar
I did listen. You yourself said you were guessing. I'm just saying I'm not guessing.
