Old 08-07-2017, 01:30 PM   #26
Jimmy E. James
Originally Posted by Tuff240 View Post
I did listen. You yourself said you were guessing. I'm just saying I'm not guessing.
Never said anything about guessing friend - go back and read the post(s)
I said "NO" guessing to it
Jimmy E. James is offline   Reply With Quote
Old 08-07-2017, 01:31 PM   #27
Tuff240
240 Ninja
Tuff240's Avatar
Originally Posted by Jimmy E. James View Post
You can't shave enough off a head to make it an interference engine (well, guess you could but then you couldn't use the head)
-Patrick
Old 08-07-2017, 01:38 PM   #28
Jimmy E. James
So now we need to get into an English lessons - word meanings change depending on context
So here you go, I'll make the statement you're chewing on easier:
You can't shave enough off a head to make it an interference engine (well, you could, but then you couldn't use the head)
Any other questions just PM me
Easy to see why you're behind the counter, autozone or o'reilly?
Slow day?
Old 08-07-2017, 01:42 PM   #29
EivlEvo
3 posts with "info" and 2 pages of bullsh*t.
Good work. Has anyone found out if the OP has blown up their car yet?
OP... are you sure you're encountering valves to piston interference, and not just compression? Does it spin freely with the spark plugs out? Have you shimmed it or better yet, measured for shims on the spots you can?
Old 08-07-2017, 01:47 PM   #30
Tuff240
240 Ninja
Tuff240's Avatar
Slow day?
Let me ask you this way. What makes a head unusable by shaving it?
I'm also curious to know why you think "turbo heads are fragile"?
And I don't really work behind a counter and never have, I'm actually retired. It's just something JV used to say to me when he was trying to insult me. I always thought it was funny so I put it in my sig.
Old 08-07-2017, 02:54 PM   #31
sbabbs
sbabbs's Avatar
Shave it too much and the cam belt's too long she said. How you gonna fix that parts boy? I'll tell ya, pinto belt. Everybody knows that.. Ha. Maybe you cranked your cam caps too tight and the cam is binding stuck and has nuttin' to do with valves hitting pistons. Just my input.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 542K MILES
Old 08-07-2017, 03:20 PM   #32
Pro Sneaker Peddler
WTF do you mean with "'info'"? Spec was provided per the manufacturer of the damn cam:
duration/lsa/lift/valve opening spec at crank TDC
Old 08-07-2017, 03:31 PM   #33
Jimmy E. James
Yeah, if it's on the internet you know it's "right"
Chill, "Harland"
Old 08-07-2017, 03:49 PM   #34
John V, outside agitator
Originally Posted by gsellstr View Post
I would see your point if you cut the head .060" and put an M cam in it with the pathetic lift it has, but if you cut the head and still have a cam with any kind of lift, yeah, it'll still be usable AND be interference. If you have .030" from valve to piston on a bone stock setup (SWAG, varies with cam obviously), you trim .035" off the head, yeah, it's interference. If you trim off .020" (min-spec on the 530) and go from a stock head gasket at .049" compressed to a tight squish gasket at .030", then it's interference, but the head sure as hell ain't a door stop.
IPD cam in mine right now, head was trimmed .010" (still .010" above min-spec), block was decked .005" to get desired piston height, .035" cometic, mine is no doubt interference.
Gary if chamber is 12mm deep, and gasket is 1mm and piston zero deck at TDC sounds like there is minimum of 13mm or .511-.512" from crown to valve..
Shave the head 060/1.5mm and go to a .030 or .0,76mm thick gasket abd that is now .442" or 11.22mm valve to crown>>
Now look at this:
Notice where intake opens..And where it closes..midway is theoretical max lift..Do the math yourself..You'll see max life is in that example 105 degrees AFTER TDC.
Where's the piston when the crank has rotated 105 degrees past TDC?
The piston is way the fawk down the bore at 105 ATDC..
How much valve lift at TDC? maybe 1 to maybe max 2mm at TDC...
Sure you can put the rubber band on wrong and break a belt but there's always a scenario where by carefully fawking up things damage can occur...
But piston to valve contact is really hardly anybody here---aside from me who even builds really nasty snortin n.a. motors around here?---needs to obsess on endlessly for years and years and years...
16V yes but 8v meh.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 08-08-2017, 12:32 AM   #35
gsellstr
gsellstr's Avatar
I get it John, I was just trying to explain to someone how shaving a head just a little can make it interference should the belt snap. You posted the numbers for the head which I didn't have off-hand. so in your example, shave .060 and run a .030, that puts it at .442 clearance, with a cam running .468 lift. Hmm, sounds like that would become an interference motor, even if the head was only shaved .040".
That whole physics thing escapes some people I suspect.
RIP
74 144 B20
90 745Ti
Old 08-08-2017, 12:36 AM   #36
gsellstr
gsellstr's Avatar
Chill, "Harland"
So you complain about specs, then someone posts actual specs from the oe website, the people that MADE the cam, and you say it's not trustworthy since it's on the internet?
You also need to chill a little dude. I'm not trying to get into a pissing match, but if this thread does continue down the road you and a couple others are trying to steer it, I will delete posts or lock it down.
Old 08-08-2017, 12:49 AM   #37
Lotta crap going on all at the same time and words all happen letter-by-letter..Always hard to logiically or clearly 'splain a dynamic process..
But specifically to the chance of valve to piston interference or valve to valve interference (huh? yeah can't happen with 8 line valve--an advantage for TB level guys who want to try crazy stuff) is miniscule EVEN if the rubber band goes twang..The valve just closes And sometimes (done it) the piston just nudges the valve closed Piston going up is "chasing the exhaust valve"..that's the scariest thing but all its done those times I've done it is slam the valve straight up an closes it and leaves a REAL scary mark in the carbon...
I looked to refresh memory---that's how you remember things (or how I remember things anyway)---check it again and again, and looked at some cams like I use in n.a. builds in the past..and even the baddest ass type things had "Lift at TDC" of maybe 3.2mm...Nuthing to worry about..
I think it is time to lay to rest the oooooh scary boogieman stories about 8v inline valve motors "becoming" interference in normal use or even "normal fawk ups" like being 1 or 2 toofies off on the rubber band.. or---and this is stretch--over revving and valve float...
Again 16v that's another story and with hotter cams for 215-230-240 hp builds I'm like
Old 08-08-2017, 12:52 AM   #38
2manyturbos
Actually, if he doesn't tone it down to a level I call civil, I'm going to delete him for a few days. Had I been on my PC instead of my I-Phone earlier it would have already happened.
Old 08-12-2017, 06:41 PM   #39
DaBossk
DaBossk's Avatar
Guys I'm confused... so it seems like most people who run the ipd turbo cam don't run it at "0" they run it normally anywhere from -4* retarded to +4* advanced
Anyways I did get the cam installed with the stock cam timing and tbh I couldn't really tell the car had a different power band.
So Harlard recommended I run the car at -4* retarded...
Here comes the laughable noob questions...
How the heck do you make the cam -4* retarded??????
I have this adjustable ipd cam gear here and tbh I guess I don't know how to use it.
would advancing the cam timing +/- 4* mean I just need to make the cam gear 3 teeth off?
Do you even boost?
DaBossk is offline   Reply With Quote
Old 08-12-2017, 07:20 PM   #40
esmth
dirty swede
esmth's Avatar
That gear can only change the timing on the increments noted on the gear, so it cannot do 4* retarded but it can do 5* retarded.
To change it to 5* retarded remove the gear from the camshaft and make sure the pin on the cam goes into the hole with the "-5" line.
1991 244 +T LH2.4 m46 283k miles with B cam advanced 4*, 962 fuel & 148 ezk, T5 white injectors, 2.5" exhaust w/ magnaflow straight-through & some kaplhenke suspension goodies
Old 08-12-2017, 07:39 PM   #41
DaBossk
DaBossk's Avatar
How would I go 4* retarded? would I need a different cam gear?
Old 08-12-2017, 07:45 PM   #42
Yes you would need a fully adjustable gear with inner and outer halves bolted together.
how psi stock can support?
Old 08-12-2017, 08:12 PM   #43
DaBossk
DaBossk's Avatar
hmm okay. I'm gonna try 2.5* advanced. would I turn the cam gear CW or CCW to make it advanced?
Old 08-12-2017, 08:12 PM   #44
Pro Sneaker Peddler
I highly advise against you running this one. Get a unit from STS or Yoshifab per Ken's suggestion above.
Old 08-12-2017, 08:22 PM   #45
gsellstr
gsellstr's Avatar
Reasoning Harald, just curious.
Old 08-12-2017, 08:41 PM   #46
esmth
dirty swede
esmth's Avatar
The fully adjustable gear would be even more confusing to OP
Old 08-12-2017, 09:35 PM   #47
J_Jones
J_Jones's Avatar
Following this as I'm using the IPD turbo cam and a similar cam gear.
