Old 08-07-2017, 10:48 PM   #1
Classic 240
Wagons Forever
Classic 240's Avatar
Default m47 input seal
The trans is out of the car, bellhousing off. The side where I would normally pull the seal has a washer pressed in after the seal. How does this come out with out bending it, because it looks like I need to put it back with the new seal?
The parts kit: https://www.eeuroparts.com/Parts/406...-M47-41431575/
has the front seal (input shaft) and an O ring listed as oil seal between bellhousing and trans case according to this thread: http://forums.turbobricks.com/showthread.php?t=260848 So, where does this go?
85 245 gl redwood
91 240+Ti teal wagon-teal two
92 244 off to school
96 855 silver glt
Classic 240 is offline   Reply With Quote
Old 08-08-2017, 02:29 AM   #2
The "washer" is part of the seal. It doesn't get re-used.
The aftermarket seal kits come with a different style seal.
F & G are speedometer seals only used on early M47's.
Old 08-08-2017, 11:26 PM   #3
Classic 240
Wagons Forever
thanks!
Old 08-09-2017, 02:10 AM   #4
planetman
planetman's Avatar
I strongly suggest you get an OE front seal if you got 1 of the cheap ones in your gasket set. I'm a fan of using OE or OEM seals even if they cost a bit more when the seal is in a hard to reach area. And I believe you would agree that this is not an easy seal to access.
Volvo still sells the original ones for $11.53 and I usually have them in stock.
Some of the aftermarket gasket sets come with the OE front seal and some don't.
Before I sell or use an aftermarket transmission gasket set with 1 of the cheap aftermarket seals for the M40/M41/M45/M46/M47 and the 4 cylinder version of the M410, I replace it with an OE seal.
FYI, they all use the same front seal, Volvo part number 1377748.
Eric
Torrance, CA 90502
