Old 08-08-2017, 10:24 AM   #1
bartman1234
bartman1234's Avatar
Default front lower control arm rear bushings, same?
Hi couldn't find the answer for my clunk in the front during low speed turning, but I read where left side rear bushing is different from right. I read that this is because there is greater pressure on the drivers side?:help
bartman1234 is offline   Reply With Quote
Old 08-08-2017, 10:43 AM   #2
mopar318
mopar318's Avatar
They are the same.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 08-08-2017, 10:57 AM   #3
bartman1234
Frustrating, I have checked the cross member bolts for tight (100lbs) checked the steering rack for tight (torqued to spec) checked the gland nut (Bilstien HD) could not get to move (couple threads showing).
New ball joints,ipd sways, ipd front bushing kit 125381, did not replace strut bearing as they did not seem worn. This is a turn the wheel almost full lock and pop or clunk, sometimes also reversing over bump. Any other things? I'm trying to figure without going to the shop.
Old 08-08-2017, 11:00 AM   #4
Eleven
Eleven's Avatar
I'm in the EXACT same boat (minus new bushings). Upper mounts checked OK. Only difference here is that my rack is on the way out, both bellows full of P/S oil. Have you checked that?
'76 245DL 235k miles
'90 240DL 350k miles
Looking for: 'turbo-style' chin/spoiler, '76 240 glovebox door
Eleven is offline   Reply With Quote
Old 08-08-2017, 11:00 AM   #5
bartman1234
Buddy suggests I've got the wrong bolt in the bushing as it is not Volvo just a 12mm with washer/washer and nylock. He suggests manufactures sometime differ in size???
Old 08-08-2017, 11:12 AM   #6
bartman1234
I do not have any leaking and reservoir stays the same so Im pretty sure not the problem. I was just reading another thread and someone claimed the 2 rear bushings L and R were different volvo part #s.
Old 08-08-2017, 11:38 AM   #7
thismachine13
Check your sway bar end link bushings.
Old 08-08-2017, 01:32 PM   #8
benski
Post
This is something that I had happen. They're cheap and easy if there's any doubt.
Old 08-08-2017, 02:10 PM   #9
Early 200 series cars did use different bushings left & right, but were updated to the same bushing.
Try tightening the 3 bolts that hold the rear bushing bracket to the frame. The bracket can shift under high loads and cause a clunking noise.
Old 08-08-2017, 02:28 PM   #10
Tuff240
240 Ninja
Tuff240's Avatar
Stock springs?
Top hat could be binding up and when you turn causing the spring and top hat to pop as they move on each other. Worth checking if you are out of ideas.
-Patrick
Tuff240 is online now   Reply With Quote
Old 08-08-2017, 02:58 PM   #11
KeizerBrickGuy
KeizerBrickGuy's Avatar
I mentioned this in his other thread. Glad someone else agrees.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 08-08-2017, 03:36 PM   #12
Can play the blues
I agree with you guys agreement. I just did a front end job on my friends 1990 wagon and his does this when backing up turning the wheel. Otherwise quiet. we chalked it up to the spring and seat popping as described. Not gonna worry about it.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 08-08-2017, 04:37 PM   #13
Rusty_ratchet
Rusty_ratchet's Avatar
I think I read that there is a proper orientation to the springs. Could the incorrect orientation cause popping?
Rusty_ratchet is offline   Reply With Quote
Old 08-08-2017, 04:47 PM   #14
KeizerBrickGuy
Anything is possible. There's a specified orientation for the rear springs.
Old 08-08-2017, 04:59 PM   #15
2manyturbos
Stock springs?
Very common issue. That would be what I would suspect first considering all the work you just did. My 940 does it all the time. It is annoying as heck. Aftermarket replacement strut mounts on that car. I have a feeling the bearings on those are low quality.
Old 08-08-2017, 05:44 PM   #16
Tuff240
240 Ninja
Tuff240's Avatar
Yes
Old 08-08-2017, 07:44 PM   #17
Can play the blues
Isn't popping what break dancers do?
Old 08-08-2017, 08:04 PM   #18
bartman1234
They are the IPD sport springs??
Old 08-08-2017, 08:08 PM   #19
Khrrck
Professional Amateur
Do 240s do it as well? The described situations and noises sound very similar to what I've had since I bought the thing. Always figured it was something like that.
'87 240 budget wagon.
Old 08-08-2017, 09:04 PM   #20
TestPoint
TestPoint's Avatar
Late comment:
My suspension popping turned out to be a failing lower rear bushing even though it was a new Turkey/India/RockAuto/et. al. bushing. Couldn't be felt by hand up/down/left/right but when removed it was obvious that the rubber/sleeve was in the process of separation.
Two pro shops had not identified the problem.
Ford V8 Conversion Manual -
TestPoint is online now   Reply With Quote
Old 08-09-2017, 12:08 AM   #21
Rusty_ratchet
Yes
How can one tell the proper orientation of the springs?
Old 08-09-2017, 02:46 AM   #22
Tuff240
240 Ninja
Tuff240's Avatar
They have indents where the ends fit. Top and bottom.
Old 08-09-2017, 05:59 AM   #23
Otto Mattik
Otto Mattik's Avatar
I had "popping" only after installing new Lesjofors HD springs up front. I worried the Bils HD's weren't matching up (As I wasn't able to remove gland nut &/or check for bottom cartridge spacer, &/or after riding inside IPD lower springs). After a question to Quilc, he mentioned spring seating (I forgot about it). On the driver's side I fussed & twisted the spring with cloth on it, & a vise-grip, yet on the pass side, I did nothing except raise then lower. Later both springs re-seated themselves. No more "clunking"
Originally posted by Jack
"You talk about parts cannon but you throw the Obamacare diagnostic tool orgy onto this like it's a cloned embryo of baby Jesus"
_______________________
Future need of elf assistant for interior work - cash/beer option
Old 08-09-2017, 08:54 AM   #24
bartman1234
My noise feels like it is coming more from the floor (lower rear bushing?)than the strut. Testpoint what did you end up replacing with as this may be my situation, even though bushings are relatively new.
Old 08-11-2017, 04:26 AM   #25
Otto Mattik
Clunk or clank ?
