Old 08-11-2017, 07:49 AM   #26
bartman1234
bartman1234's Avatar
No clank just clunk, bordering on kerplunk!
bartman1234 is offline   Reply With Quote
Old 08-11-2017, 08:35 PM   #27
TestPoint
TestPoint's Avatar
Originally Posted by bartman1234 View Post
Testpoint what did you end up replacing with as this may be my situation, even though bushings are relatively new.
Since the right side seemed solid I ordered one from AutoZone since they got it to the store 2 days quicker than Advance and it had become my daily driver.
I rebuilt the entire suspension system with parts from RockAuto. I didn't even low ball prices as even some of name brand pieces were from Greece, Pakistan and maybe others. I just didn't go for the very premium stuff. Everything is doing fine except for that one left rear lower bushing. While I certainly knew better I cannot swear that the wheel was carrying the entire weight of the car when I tightened down the nut. On replacement, I realized that seriously tightening that nut with the big V8 right there might have been difficult. That is the most likely cause of a premature failure.
That was about a gallon of olives ago.
Ford V8 Conversion Manual -
Old 08-15-2017, 08:50 AM   #28
bartman1234
Problem solved.
Thought I might post this in hopes others possibly may find a solution to there front end clunk/pop.
After replacing all bushings on the car, my technique was drill out old rubber, remove inner sleeve and reciprocating saw gently a score top and bottom outer sleeve, easily pops out with hammer and cold chisel. Finish by running the dremel around opening to smooth inner lining. Grease new bushing, pushes right in, easy peasy. With the lower control arm front bushings, there is enough space to allow the outer sleeve to side back and forth with the play available from the rear bushing mount, possibly 1/4" or so. This was my clunk, turning torque was sliding bushing in control arm housing. My solution was to tack weld bushing to control arm. Long story short, if you have a clunk, look into the front cross member and if the bushing is not fully seated, that could be your clunk.
Old 08-15-2017, 09:02 AM   #29
TestPoint
TestPoint's Avatar
That front lower bushing should have been tight enough between the shoulders of the control arm that tightening the bolt/nut should have prevented any movement. Perhaps you had some control arm damage or the wrong bushing.
Most auto parts stores will 'rent' you tools to make removal/install of bushing an easy task.
Old 08-15-2017, 09:16 AM   #30
bartman1234
The inner sleeve, where the bolt runs through was tight. Being rubber, it was allowing the outer sleeve of the bushing(shorter) to move back and forth in control arm opening.
Old 08-15-2017, 10:08 AM   #31
TestPoint
TestPoint's Avatar
That just doesn't seem right. I'll crawl under the car today to have a look.
If the inter sleeve is held tight by the bolt/nut and you tack welded the outer sleeve to the arm you just eliminated any reason for there being a bushing there.
Old 08-15-2017, 10:45 AM   #32
bartman1234
Not so, it stops the outer sleeve from moving in the control arm sleeve
Old 08-15-2017, 06:16 PM   #33
TestPoint
TestPoint's Avatar
I am just trying to understand because I lived with a clunk in the left suspension for most of a year until it got bad enough to find it.
Here is the front lower bushing. Mine has no room to move once the nut/bolt through the bushing is tightened. That is why I questioned if you have a damaged front cross member or control arm or an incorrect bushing.
Old 08-16-2017, 06:48 AM   #34
DET17
Reformed SAABaholic
Seems an appropriate time to mention... all the OEM rubber "shear bushings" that twist in torsion as suspension articulates, must be thru bolt torqued to spec at RIDE HEIGHT.... not with suspension drooooooping on jack stands. Can be a PITA on lowered vehicles, but that is the proper technique so the bushing torsional strain is + / - as the suspension moves. I.E. it is neutral at ride height. Sorry, my OCD is acting up this morning.....
Old 08-16-2017, 08:46 AM   #35
bartman1234
Tried to sketch my explanation.
