Old 08-08-2017, 08:05 PM   #1
Coffee
Default 1990 245 +t ****s the bed under boost
So, i've got a sweet ass +t, 1990 245 with an M47, which has been my reliable daily since 2009. I've got some fun stuff bolted to it, B cam, TLAO chipped ecu/ezk, orange top injectors, MBC set to 9 psi, 2.5" cat-less exhaust, magnaflow muffler, it's great fun. At least it was while it was running normally.
Just recently I was doing a high speed pull on the highway and my car lost all power. I could stand on the throttle and it would occasionally give me small blips of gas, but that's it. I shut it off, started it back up and was able to accelerate back to freeway speed, but if I tried to hop on the throttle it would fall flat on its face again and go straight into "retarded mode"
Now it is sitting in my garage, being a rusty sack of ****. I've been pouring through every thread I can find, replacing parts and generally tearing my hair out that nothing seems to be helping.
Here are my symptoms
Terrible idle, car keeps trying to die
Drives fine (as far as I can tell, cant really leave my neighborhood) until I hit boost, chokes in a very hard way around 4000 RPM
Goes into retard mode where idle becomes even more erratic and car will only rev in blips, independent of how much throttle input i give it.
In neutral when revved engine speed will increase incrementally by 1K rpm to 4k, but go no higher. other times it seems to rev freely without hesitation
Parts i've replaced:
crank position sensor
fuel pump (single in tank dw200 with DW relay kit)
IAC
Injectors (one was leaking badly onto my intake manifold)
AMM
spark plug wires
spark plugs
I don't feel like i'm explaining any of this well enough, is there something i'm overlooking? This car just passed emissions the day before all this **** started and i'm getting to the end of my rope here.
Feast your eyes on this Super-Dope ride.
Coffee is offline   Reply With Quote
Old 08-08-2017, 08:15 PM   #2
Pro Sneaker Peddler
Do you have a stock 7/9 pre-turbo intake hose?
Also, put a cat in it, it's selfish not to and not running one really does ****all for improving performance for you. Don't be silly.
Old 08-08-2017, 08:31 PM   #3
Coffee
No, I have a shortened section of intercooler piping with my amm/cone filter on it, and a forge 007 recirculating back to it.
Old 08-08-2017, 08:32 PM   #4
thelostartof
unbalanced chemical
thelostartof's Avatar
Have you checked for boost leaks? Torn hose someplace? Done a pressure test?
Do you have pictures of your intake hose between the turbo and AMM? Is this hose sucking shut the first time you get near boost and maybe staying shut?
Have you checked if your FPR has failed and is leaking fuel into the intake (typically this would show up as bog and miss until you get into boost and then it revs fine).
Sure sounds like you have a major boost leak.
Old 08-08-2017, 08:41 PM   #5
Pro Sneaker Peddler
A gigantic sound of rushing air is a pretty obvious sound of a boost leak, OP. But as Mike said, a big ol tear in an intake coupler will also do it.
Old 08-08-2017, 08:43 PM   #6
Coffee
I have not pressurized the system to check for boost leaks. i did a fairly in depth visual inspection while I was out there earlier with a propane tank seeing if i could alter the idle but, no go. ill snap a picture of this greasy bitch right now.
Sweet chips BTW, best modification I ever did for the car.
Old 08-08-2017, 08:44 PM   #7
thelostartof
unbalanced chemical
If it never gets into boost he might not hear the air rushing, and then again most people do not pay attention to the little noises thier car makes as they might hear something but not really know what it is. I recently had a tear in an IAC hose that would make an odd noise under boost. But a big leak you might not hear.
This is another reason open downpipes suck.
Old 08-08-2017, 08:44 PM   #8
thelostartof
unbalanced chemical
Old 08-08-2017, 09:56 PM   #9
Coffee
https://ibb.co/dQPnBa
I'm not the best photographer.
Old 08-09-2017, 01:19 AM   #10
Pro Sneaker Peddler
I see stock rubber air hose there. Can you pinch it together by hand?
Old 08-09-2017, 08:10 AM   #11
Dadssleeper
IAC
AMM
spark plug wires
spark plugs
Have you cleared up your codes, last time we talked you had a 1-2-3- and a 2-2-4 ...both ECT sensor codes. Also forgot to mention that and thats very important for diagnostics.
Old 08-09-2017, 12:13 PM   #12
nordmaschine
forced instruction
nordmaschine's Avatar
Once upon a time, I had the same thing happen to me when I split recirculation valve clean in half.
Yours might just have a torn diaphragm, but if you don't see anything obvious wrong with the rest od the hoses, check that. If you're not sure, just remove it and block the hoses, take it for a light spin and report back.
Jetronic is romantic.
Whiteblocks
Old 08-09-2017, 12:50 PM   #13
I agree that no boost is commonly an air leak. Smoke, pressure and soapy water, or pull all hoses and inspect.
Old 08-09-2017, 12:57 PM   #14
nordmaschine
forced instruction
You should really get this new labscope plugin for that, it measures air duty cycle and all. Smoke and soap are so last decade and unprofessional.
