Old 08-09-2017, 10:07 AM   #1
chevy_dude97
Default 89 745 fuel return line leak
So, after carefully cleaning all the grounds on my headlights to get them TUV approved brightness, I was distraught to hear the inspector call me under my car after what I thought would be a quick win. He quickly points out a fuel line that had rusted to the point of a seeping leak, then fails my car.
After closer examination of my 1989 740 wagon with sohc 2.3l, I noted the suspect line is the green line running from the pressure regulator.
Is there a replacement line I can pick up that only goes from the regulator to the joint in the middle of the car? It is all covered in undercoat but I can tell there is a coupling in the line just behind where the other line goes into the fuel filter(not green line). I have searched rockauto and the like but I cannot seem to find the part to order, I have also tried "googling" it including a search of this forum, but it seems that the banjo bolts is always the topic that is returned. Any help is much appreciated.
1989 740GLE 8V 250K miles in Survivor mode
1951 Buick Super
1980 MG MBG GT Sebring
2001 Seat Alhambra 1.9TDI
chevy_dude97 is offline   Reply With Quote
Old 08-09-2017, 01:28 PM   #2
Can play the blues
I would try looking at gcp.se catalogs and see if there is a part listed. Then you can try to buy it from either them or one of the other suppliers like Skandiix that get genuine parts.
1982 242 turbo. 339k miles. Stuff...old stuff....cool...old...stuff...rust...not...cool...
1993 245 Classic, 413k miles, enem V15. 5spd. IPD bars and chassis braces. New Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
1981 242 turbo. 71k miles. Cool old stuff...
1969 145S more cool old stuff. A barn car.
1967 123GT yet more cool stuff in the barn.
Old 08-09-2017, 03:10 PM   #3
http://www.skandix.de/en/spare-parts...ction/1058839/
Old 08-14-2017, 03:40 AM   #4
chevy_dude97
Thanks guys, I didn't even know about SKANDIX!
Old 08-14-2017, 04:32 AM   #5
chevy_dude97
Looking through the IPB(Integrated Parts Breakdown) from the catalog. I have come to the conclusion that this part(3528027) is in fact the one I am trying to replace. It is funny that SKANDIX does not show this part as fitting my vehicle specifications, I do not think I would have found this on my own. Thank you for your time!
Old 08-24-2017, 04:52 AM   #6
chevy_dude97
Good and Bad news, good news is the line was the correct length and bent correctly. Bad news is the fitting was placed on the wrong side of the line.
On the blow up parts diagram, it shows fittings potentially on both ends. On my vehicle there was only a fitting at the rear end of this line and was double flared on the engine side where it meets up with a rubber fuel line.
When I received the line I was ecstatic as it appeared the same, however when fitting to my vehicle I noted the compression fitting was on the wrong side(towards the motor) and the double flare was at the rear. I double checked all part numbers both volvo and skandix just to make sure I recieved the correct line.
I ended up just removing both ends so I could refit the fitting and flare both ends again. As everyone knows flaring steel lines is a pita.
Aside from all of this, fuel line is inspection ready!
