Old 08-10-2017, 02:33 AM   #1
mattd1205
mattd1205's Avatar
Default 1991 240 hard start when hot and hunting idle for a few seconds after
I have an issue with starting my '91 240 when hot.. it cranks for a couple seconds and when the engine fires the idle hunts until I rev the engine once and then it idles well. Cold starts are perfect. I put a new FPR in 9 months ago, I checked the resistance on the coolant temperature sensor and the MAF (both are in spec), injector o rings are less than a year old, vaccuum lines are a month or two old, fuel filter was done 6 months ago, the throttle body was cleaned about a year ago and there are no codes. What's left to check? IAC valve?
Thanks
Matt
mattd1205 is offline   Reply With Quote
Old 08-10-2017, 09:47 AM   #2
EivlEvo
It does this when the AMBIENT temp is hot, or the motor is hot?
Sounds like vapor lock to me. What's your fuel pressure like?
