Old 03-04-2008, 04:33 PM   #26
thelostartof
unbalanced chemical
thelostartof's Avatar
clamp off hose
Old 03-04-2008, 04:45 PM   #27
orie
Doctor Who
orie's Avatar
I did block off the PCV hose hole that goes into the AMM to turbo pipe, but i left the PCV side sitting free, that's where I felt the slight positive pressure. Should i block that side too? intuition says no, as i could blow out seals..
orie is offline   Reply With Quote
Old 03-04-2008, 05:24 PM   #28
gsellstr
gsellstr's Avatar
BUT did you unhook the vacuum supply hose that goes to the flametrap? You'll get pressure from the manifold and out the larger PCV hose that way. Don't ask me how I know....
RIP
74 144 B20
90 745Ti
Old 03-04-2008, 06:06 PM   #29
orie
Doctor Who
orie's Avatar
lol, no i didn't. That's probably the key. Hopefully I didn't blow any seals. Thanks!!
Old 03-04-2008, 06:27 PM   #30
gsellstr
gsellstr's Avatar
If you blew seals you've got other issues to worry about. The amount of air going in via the PCV vacuum line won't be enough to be an issue. Any other air is simply air that's getting past the rings or valve guides, both of which you'll have much higher pressures under normal engine operating conditions.
Old 05-19-2008, 10:01 PM   #31
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
I bought a metal/rubber plug at Ace today, jammed it into the AMM hose (headed towards the turbo inlet) and fed air in thru the PCV breather hose. I couldn't hear any air escaping from anywhere, but it certainly wasn't holding any pressure. If I held my thumb over the PCV tube then it would build a little pressure. But the pressure goes away in about 2 seconds if I move my thumb or not.
I was using a smallish air supply tip so maybe that was part of the problem. I'll try it again with a full air supply (LOL! I said Air Supply) like was shown in the original post.
Any ideas from what I've seen so far?
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 05-19-2008, 10:55 PM   #32
Brandon
Brandon's Avatar
Is test cap the official name for that one part? Maybe it's just the ignorant schmuks in my Home Depot, but no one had ever even heard of one.
Originally Posted by golgothan
Here is what you do to seal the deal, text her a picture of your nut sack stretched over a pine cone. I don't know why but girls totally dig it.
Brandon is offline   Reply With Quote
Old 05-19-2008, 11:54 PM   #33
stylngle2003
stylngle2003's Avatar
i found mine at lowes
-Billy
1990 Mazda Miata (track toy)
Old 05-19-2008, 11:58 PM   #34
gsellstr
gsellstr's Avatar
Cleanout cap or just a plain cap, depends on what you're looking for.
Without capping the throttle body end of the intake tract you'll still be losing air thru various ports on the manifold, plus thru the one or two open valves and out thru the exhaust. Now if you pull the cam you can deal with that leak as well.
Old 05-20-2008, 12:25 AM   #35
Eargasm
Eargasm's Avatar
They're usually found on the same isle as the ABS and PVC. They use similar caps for wells so you might ask for a well cap.
Eargasm is offline   Reply With Quote
Old 05-20-2008, 01:48 AM   #36
dhallilama
dhallilama's Avatar
Nearly every Home Depot i've been in seems to have the test cap in question... though few people who work there seem to know a damned thing... a shame, really.
Home Depot USED to have knowledgeable people in all their departments... and pay 'em pretty well. then they fired everyone. There are still the scattered well-informed people, but they're getting fewer and and farer in between...
Anybody local (PDX) who'd like to borrow it is welcome to... just drop me a PM. can take it with you and return it, or go ghetto fab style and use it in front of my house... and if'n ya feel like bringing a beer, i drink Iron City (or anything, really).
-'72 volvo 142e b20, holset, ms, etc.
- III -
dhallilama is offline   Reply With Quote
Old 05-20-2008, 09:07 AM   #37
Chris_R
Chris_R's Avatar
The PVC cap and the test plug were almost the same price... ~5 bucks. I opted for the metal adjustable piece rather than trying to figure out which plug I really needed.
OK, so I need to cap off the throttle body side to really see if I have leaks? Doesn't that just mean that my TB doesn't close properly - or is it supposed to leak a little?
What about the IAC? Crimp/plug that too?
Old 05-20-2008, 12:37 PM   #38
stylngle2003
you might have intake gasket or injector leaks too, food for thought. just up the pressure
Old 05-20-2008, 09:50 PM   #39
Chris_R
Chris_R's Avatar
I ran it up to about 40 PSI, but it still leaked right out. Gonna try blocking off the hose at the TB and see what that does.
Old 05-21-2008, 02:26 AM   #40
Tamnakz
Tamnakz's Avatar
This thing looks f*ckin' awesome!
EMT's, Police, nurses. Apparently the State trooper got on the horn and told everyone. They didn't know it was a volvo.
'76 244 *sold*
'86 244 *crushed*
'87 745ti N/A pistons M46 *parked*
'88 745 -work status-
'89 744 *sold*
'91 944 16v -dd-
'03 V70 -travel bi***-
Tamnakz is offline   Reply With Quote
Old 06-07-2008, 03:35 AM   #41
runt262
runt262's Avatar
i realize that this is for checking the turbo lines and such. would this work for checking all the vacuum lines also? like hooking it up to the intake tube after the intercooler?
1985 Volvo 240ti
runt262 is offline   Reply With Quote
Old 06-07-2008, 04:11 AM   #42
Bishop
Bored Member
Bishop's Avatar
Yes, it will leak test just about everything in the intake system, when I did mine I actually just disconnected the top hose coming from the turbo, found the base of a cup fit in the hose, then tighten the clap again.
To pressurise the system I pulled a vac hose and shoved the air duster fitting from my compressor into it, that was back when I found my idle air control hose was leaking, and it was one of those leaks you probably would have never found without a pressure test.
If a mod wrote this, it would be hell funny...
Bishop is offline   Reply With Quote
Old 06-07-2008, 06:09 AM   #43
Jerd
Jerd's Avatar
Yah know, at first i was thinking, "very good quite professional good job" and i started to wonder where i was. I felt like i wasnt here anymore. and then i scrolled down....
"will a bike pump work?"
"i used cardboard and duct tape"
Oh yeah now i remember.. TB should stand for ghetto.
Old 06-07-2008, 08:57 AM   #44
740Weapon
Traitor
740Weapon's Avatar
to add.
this also works for n/a cars.
just turn off the compressor at like 2 psi.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 10-20-2008, 10:25 PM   #45
Tamnakz
Tamnakz's Avatar
Bump so mo peeps see the goodness!
Old 10-20-2008, 11:53 PM   #46
DrvSfly
Bored Clown
DrvSfly's Avatar
Thumbs up
Originally Posted by 740Weapon View Post
to add.
Go ahead and give that na car the same boost.
I am inspired. I'm gonna build one of these while I am looking for MBC parts.
Drive Safely
I think we'll either get rid of religion, or it will get rid of us.
'83 245 TIc sold
'97 960 totalled
'94 745 totalled (not mine)
'87 744 totalled (not mine)
'91 780 totalled and sold
'81 b21f, T cam, Lh2.2, 960 injectors, junkyard/back of the shop 15" trash rims. - Sold
DrvSfly is offline   Reply With Quote
Old 10-21-2008, 12:12 AM   #47
surfbug
yes, this needs to be done to the silver 88 765ti...soon!
Originally Posted by amargill19 View Post
Yup, that's a mull. And it's a pretty high rater - Pure business up front, party out back. Excellent.
Originally Posted by WheyDey View Post
...its so nice to have a mullet expert on board, isnt it?
CURRENT RIDE->'88 765ti 10/08 222k. OLD RIDES->'89 765ti 207k 10/07 to 2/09, '87 765ti 9/06 to 10/07. FAM RIDE->'98 v70 awd xc 6/08-- 8/13 new addition! - '94 944ti 248k current DD. also...2002 e46 325ci conv 58k miles..for sale now! pm for info
surfbug is offline   Reply With Quote
Old 10-22-2008, 03:28 AM   #48
Tamnakz
Tamnakz's Avatar
I built mine today (well, yesterday now).
Used a piece of galvanized fitting that fit right in the amm -> turbo hose and a plastic cap.
I put a valve stem in the cap, and used a gauge hooked into the vacuum line that runs to the charcoal canister.
Worked perfectly, found two leaks, and confirmed the third I knew was there.
Old 10-23-2008, 05:19 AM   #49
Elvira_745T
Elvira_745T's Avatar
Thumbs up
This is great! I'm just about to finish up on my headgasket repair job, this will come in handy when I get everything back together! I <3 homebrew tools!
In order of appearance:
1967 VW Karmann Ghia
1973 Vespa 90 (shhh 135cc)
1986 VW Golf GTI
1992 Volvo 745 Turbo
They all start with a "V" and are European, sweet!
Elvira_745T is offline   Reply With Quote
Old 06-24-2009, 10:35 PM   #50
691800s
Hey,
I went out to the Depot today and got the stuff to build one of these fancy boost leak testers (although prices are up! Almost 20CAD). Great idea, thanks dhallilama. I've got an 84 245Ti... B21ft with intercooler. What hoses will have to be capped off to use this properly? Do I simply cap off the PCV hose that runs over the valve cover? Have people found it necessary to block off after the TB?
Thanks!
69 1800S
07 S40 T5 manual AWD
691800s is offline   Reply With Quote
