Old 06-25-2009, 12:59 AM   #51
dhallilama
dhallilama's Avatar
^^ all i've ever done is cap off the PCV...
the TB won't block all the air, but it generally doesn't matter... hooked up to a compressor (even a 5 CFM P.O.S.), you'll have plenty of air.
glad to see people are using this cheap trick... i totally forgot about posting it here. i end up using the thing (or one of the various sizes i threw together) pretty often. found an intake leak on my NA b20 about an hour ago, and another on my harley yesterday... works just as great on NA motors as it does on turbo motors. whoever the first person that came up with this should have beer bought for him for life...
-'72 volvo 142e b20, holset, ms, etc.
- III -
dhallilama is offline   Reply With Quote
Old 12-02-2009, 04:10 PM   #52
lammmy
lammmy's Avatar
So, just to be clear here, what hoses do you have to block/clamp? Disconnect the PCV hose on the AMM --> Turbo hose and then fill the hole? what about the ones on the cold-side? Anything over there I should be blocking off, say the one that runs to the IAC or anything?
lammmy is offline   Reply With Quote
Old 12-02-2009, 04:21 PM   #53
orie
Doctor Who
orie's Avatar
Technically, none of them. The whole intake system can take pressurization, just make sure you set yer regulator at about 10-15psi or you might pop hoses off (as with raising boost). Hell, it's probably a good test before raising boost. Too high a pressure and you may damage things, such as the climate control system.
Edit: intake system excluding the PCV of course.
orie is offline   Reply With Quote
Old 12-02-2009, 05:19 PM   #54
lammmy
lammmy's Avatar
That's what I'm talking about, how do I "exclude" the PCV system?
Old 12-02-2009, 05:36 PM   #55
orie
Doctor Who
orie's Avatar
Just block the vacuum line coming from the intake manifold and plug the PCV nipple on the airbox to turbo with something. I used an old wine cork. Thought you already knew that, sorry!
Old 12-02-2009, 07:09 PM   #56
lammmy
lammmy's Avatar
In my head I thought I should know it, but I wasn't sure...apparently I did know it, but was not confident enough to let myself know it. Thanks for the confidence booster!
Old 03-28-2013, 08:28 PM   #57
rj740t
rj740t's Avatar
Did a boost leak test on the 740 today and found some leaks.
1- leaking hks ssqv3 bov
2- leaking cold start injector O-ring
3- 2 minor leaks on intake vaccum hose
After fixing these leaks, I can't get more than 10psi on the system..
I have a 80 gal compressor.
I have Ipd cam.
I haven't done a comp test but I know compression is not so good...
Could my tired 300 000km b230ft let flow that much blowby that boost can't go over 10psi?
rj740t is offline   Reply With Quote
Old 03-29-2013, 09:17 AM   #58
r0k0
r0k0's Avatar
that or from Silicone intakes.com
30$
http://www.siliconeintakes.com/produ...a42ed512991a77
1994 854 2.4 5 Speed - Crashed in 06
1990 744Ti - Sold to Nephew
1993 245 - SOLD
1991 744Ti - Project - 16T@15PSI, Brown Tops, Side Exhaust, Intake
1993 244 M47 - SOLD
1996 854 2.4 Auto - SOLD
1987 744Ti - SOLD
r0k0 is offline   Reply With Quote
Old 08-11-2017, 05:28 PM   #59
soclosenotnear
Just wanted to bump this great thread I came across. Everyone always fails to ever boost leak their engines, even though it's always the first thing suggested when their is problem. Myself included, but not anymore. I took my trip to home Depot and will be doing this this weekend.
