2manyturbos
- Mar 8, 2003
- Monroe, OR USA
While I concede that you know all, I personally am confused..I have right here in my little hands the 1990 edition of KS Master Piston catalog and it lists everything imaginable for the pistons they make>>
On page 617 it says:
Motor B23A, 2316ccm
77kW (104,5 PS) 10,3:1
mit vergaser
Fahrzeug 244,
Oktober 1981-Mai 85
Data shows cylinder bore 96mm.......46,4 Comp hgt -3,1 x bowl, 24 x 72 pin 1,75 top ring; 2mmm second ring and 4mm oil ring
on page 618 it says:
Motor B23 A, 2316ccm 82,5/84kW (112/114 PS)
10,3:1; mit vergaser
Fahrzeug 240, 244, 245,760
Oktober 1981-mai 84
Motor B23E, 2315ccm
95-103 kW (129-140 PS)
10/10,3:1 K-Jetronic Einspritzung
Fahrzug 240, 244, 740
August 1979-Mai 84
the data says 96mm cylinder diameter 46,4 compression height Flat top 26 x 72 pin
Block 3 on page 618 shows USA-ausf?hrung
Motor B23F 2316ccm
90kW )122,5 PS= 9,5:1;
Fahrzug 240 GLE, 760 GLE,
bis Mai 1984
Data shows 96mm cylinder bore 46,4 and -2,1 deep, rings and pin as before
Now I've only been here what 11 or so years, and yes I have read about 7390 times about 10,5 B23s so it must be right what I read here...
So if TB is, as always, right the question becomes how did the alternate OEM supplier
get stuff so wrong?
It might be a good idea if TB collectively drafted a letter to
Kolbenschmidt AG
Postfach 13
D-7107 Neckarsulm
or called + 0 7132/33-0
And straightened those dumb Krauts out.
Right here in case you missed it the first time. Quoted so he can't change it again.
