Old 07-17-2007, 10:31 PM   #1
holtzboy
Back at it again
holtzboy's Avatar
Default Rear end clunking noise still there after poly install
So I got a few things installed on my 240; dale poly bushing kit, ipd panhard rod, ipd torque rods. I thought this would cure my clunky rear end but anytime I accelerate from a stop, anytime I shift gears, anytime I am driving along and let off the gas then reapply the gas I get a clunk noise coming from the rear of the car. It does have a 3" exhaust but it has plenty of clearance all around from the sway, gas tank, and rear end parts. What else could be making the noise? I almost want to goto a dyno and have someone step on the gas so I can see whats banging around!
1. 86 244DL- 1st car & Owned for 15 years, 25mm sways, iPd springs/fronts cut 1 coil, HDs, 2.25" exhaust, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 93 945 Turbo - IPD sways, 3" turboback exhaust, intake, accumulator mod
My feedback thread
holtzboy is offline   Reply With Quote
Old 07-17-2007, 10:42 PM   #2
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
transmission mount? it could still be the exhaust.did you replace the front trailing arm bushings?
Originally Posted by rvolvor
Old 07-17-2007, 10:46 PM   #3
holtzboy
Back at it again
holtzboy's Avatar
I just replaced the tranny mount with a firm Meyle brand one. They did all the bushings possible in poly.
Old 07-17-2007, 11:10 PM   #4
cst805
is so rude.
cst805's Avatar
center support bearing on the driveshaft. the rubber surround is prolly toast.
cst805 is offline   Reply With Quote
Old 07-17-2007, 11:16 PM   #5
holtzboy
Back at it again
holtzboy's Avatar
Hmm hopefully. Guess I will wait it out because I have a Getrag 265 'kit' to put on I got from sethfc. I just need to get someone to modify/make me a fancy shifter so I can get rid of the sloppy bmw one.
Old 07-17-2007, 11:21 PM   #6
Tamnakz
Tamnakz's Avatar
I've got an '86 and have a similar noise. Any time I load/unlead the drivetrain.
In other cars I've found it to be freezer bushings, but mine look fine. I replaced my center support bearing, didn't get rid of it though. Does anyoen have any other suggestions for my case?
EMT's, Police, nurses. Apparently the State trooper got on the horn and told everyone. They didn't know it was a volvo.
'76 244 *sold*
'86 244 *crushed*
'87 745ti N/A pistons M46 *parked*
'88 745 -work status-
'89 744 *sold*
'91 944 16v -dd-
'03 V70 -travel bi***-
Tamnakz is offline   Reply With Quote
Old 07-18-2007, 12:33 AM   #7
cst805
is so rude.
cst805's Avatar
In some cases the universal joints on the 2 piece drive shafts wear out and become stiff. this can cause a pretty wicked vibration when climbing through the revs.
Old 07-18-2007, 11:44 PM   #8
Tamnakz
Tamnakz's Avatar
There's no sort of vibration.
It's a solid clunk. If I neutralize, I get it. If I'm coasting in gear and give it gas, I get it. I've I shift, I get it.
Can't figure it out for the life of me.
