Turbo'd 24erty4er
- Oct 22, 2004
- Vancouver,B.C., Canada
I have read a few threads posted about swapping the NA engine/ transmission for a 940 turbo version - in my case the engine would be from a 1991 940 SE. Outside of the down pipe, inter cooler and associated plumbing, larger radiator and most likely some sort of cone filter arrangement I do not think there is too much of a problem - locating the separate power steering reservoir and a harness to operate the electric fan - not sure if one could use the stock radiator without a separate oil cooler though.
Of course one would need the ecus from the turbo car as well as relocating the distributor from the NA block and most likely the intermediate shaft as well. If I missed anything any suggestions would be helpful as I continue searching here - should be enough information.
