xrayjeeper83
- Apr 5, 2006
- Jax, FL
I think it is, it took 3 pages for you to figure out something that is really useless to know.
Yes, I am most certainly serious. A 12 year old could have figured it out by now, by just looking at where the preheat heat pipe goes Jacob. Get real.If you're in college surely you have some common sense.Your not being serious are you?
Several members told you it's best to remove it but you refuse to read or listen.
Either you have absolutely no mechanical aptitude or you're trolling. In either case just put the airbox lid back on.
You're likely not ever going to be observant enough/performance oriented enough, to notice the difference until the AMM fails anyway.
No offense, just being honest.
Yes you did Jake, in a PM. And you know it. Quit fibbing.I never called you a bad seller bro
I ran the pre heat hose to here...but i'd like to add the splash pan back on so I may have to cap that hole off..any suggestions though? I tried by the passenger light but it seemed to pinch the lower radiator hose...
^ It's that car your daily driver? That engine bay is clean
I've thrown my pre-heater hose into the trunk but I haven't found a cap for the airbox inlet, is it really necessary to cap it?
I would think that the belly pan would be good enough at keeping junk from getting into the inlet.
You can use a piece of the preheat hose attach? to bottom snout on airbox (like stock) BUT routed to the behind the grille area to place a 2nd CAI pipe next to the other/stock one.
That's what did for summer use. Or you can cap it off.
I chose to add the 2nd intake pipe for additional cool air to air box. It seems to help a little in the 3500-5200rpm range but don't expect huge HP gains
Scroll down on both of these links to see how I did it...........
http://forums.turbobricks.com/showthread.php?t=203083&highlight=smokeyfan1000&page=4
http://forums.turbobricks.com/showthread.php?t=203083&highlight=smokeyfan1000&page=5
Geez, I was just wondering if I have to cap the hose or if I can just leave it be. I've read most of the articles on your build, and I have little to say that you'd like to hear.
EDIT: I found the answer myself via Google, you only need to cap the hose if you're going in for emissions.
Unsure why or where you caught the bad attitude dude.. but it's your car ....fix it like you want to.
I don't care how you do it. Nor do I care what you think of my 240............
