Hey all,
I got my first car, a (currently) Automatic 1992 Volvo 740 Wagon (non turbo). So far things have been great. The timing belt popped the day after I got it (On an interstate highway, no less), but I had it up and running again for the grand cost of $14. Other than that, it hasn't had any major issues.
I have noticed, however, that when I commute to work on the highway, the car runs anywhere from 2800RPM to 3500RPM. I can clearly hear the engine running as though it's searching for a higher gear that isn't there.
From what I read online, this sounds very much like an issue with the overdrive system. I can hear the relay click when I hit the button however, and the OD light is not on in the dash unless I hit the button.
However, I don't think it has to do with overdrive. I say this because, this morning on my way to work I waited until I was going highway speed (about 65mph) and then hit the OD button. The RPM shot up even higher and the sound did as well obviously. I quickly reengaged it and felt the 4th gear catch and the RPM's lower to around 3,000.
Any idea what might be causing this? I'm pretty sure it's the reason my gas mileage is awful (I can't give an exact number because unfortunately the speedo is not working, although I plan to fix that this week). If I had to guess I think I'm sitting around 12-15mpg (I do 30 miles a day of highway driving).
Any ideas would be appreciated.
