Old 04-22-2018, 04:43 AM   #1
Brick-hi
Brick-hi's Avatar
Question 92 240 new fuel pump and filter
Hello once again. Today I put a new main fuel pump and filter in my 92 240 wagon. Everything seemed to go as it was supposed to. It had 3/4 tank of gas, I let the pressure out of the tank by taking the fuel cap off. It's the correct bosh pump from Ipd. It said to make sure the pump was full of gas (which I could not figure out how to do and put it all back together) Now it won't start! Does any one know what I may have done wrong ?. It ran fine before I changed the pump and filter. I'm truly stumped and I know you all have a treasure trove of knowledge and I could truly use some more once again.
Brick-hi is offline   Reply With Quote
Old 04-22-2018, 06:28 AM   #2
Otto Mattik
Otto Mattik's Avatar
Try jumper the pump/s ?
http://cleanflametrap.com/transferPump.htm
Originally posted by Jack
_________________________
Old 04-22-2018, 09:40 AM   #3
missthe1122
missthe1122's Avatar
Do you hear the pump running when you turn the key to position 2? If not, follow the instructions Otto Mattick posted. if the pump runs when you jump the fuses, then you might need a fuel pump relay.
missthe1122 is offline   Reply With Quote
Old 04-22-2018, 10:51 AM   #4
nel621
Get your test light out and make sure you have ground and power at the fuel pump terminals.
Old 04-23-2018, 01:52 AM   #5
Brick-hi
Brick-hi's Avatar
Default 92 240 wagon
I guess I should have given more info. I had replaced the intake pump and sock about a month ago. The pump & filter I just replaced is the inline one in front of the driver's side rear wheel.
Old 04-23-2018, 10:27 AM   #6
EivlEvo
How long did you crank? It takes a lot of fuel to get a new filter running.
If you cranked it for 60 seconds. Let the starter motor cool for 5 minutes. Crank for 60 seconds again.
If it doesn't start after that check your wiring and flow arrows.
Old 04-23-2018, 10:28 AM   #7
EivlEvo
They prob meant the filter. The filter full of gas.
