Old 07-27-2017, 09:14 PM   #1
Otto Mattik
Otto Mattik's Avatar
Default Sway Bar Nut
Curious about specs for (front) sway/stabilzer bar link nut ?
One fell off, I can check other side for nut size. Wondering if metric course thread from a hardware store will suffice ?
* Looked on Tasca, IPD, FCP, etc and no size or specifics given, although one site had the nut listed as a lock nut
1992 240 Volvo
Originally posted by Jack
_________________________
Feedback Link: forums.turbobricks.com/showthread.php?t=323689
Old 07-28-2017, 09:33 AM   #2
EivlEvo
TBH I don't think they're the same between aftermarket brands. I recall having to swap sockets a lot when going from old suspension crap to new crap. All stated, you should be able to find something at the HW store.
You can pull the other side (assuming you have the same ones on each side) and see... they're also like, $12 or something to just get a new one iirc.
Old 07-28-2017, 09:51 AM   #3
Centsableone
SNAFU - BOHICA
Centsableone's Avatar
Default sway bar links
FWIW - those whole links with bushings and hardware brand new are short money. IMHO if you are going through all the trouble to play with those it may be a good time to replace them and have some piece of mind.
1983 245T, 1986 244, 1990 745T, 1990 245, 1982 4- speed 245D,
Currently: 1992 244
Sale and Purchase Feedback
Centsableone is offline   Reply With Quote
Old 07-28-2017, 11:29 AM   #4
Ya except those scantech bushings are garbage, not to mention corporate shipping, just take the nut from the other side to the hardware store and match it up like anybody with half a brain would do.
Old 07-28-2017, 11:29 AM   #5
Acke
Can confirm this, I've had different sizes on each side. I think any correct size metric nut should do.
Old 07-28-2017, 03:53 PM   #6
Otto Mattik
Good advice thanks gents
Old 07-28-2017, 03:56 PM   #7
Otto Mattik
Thanks, good to know
Old 07-29-2017, 01:49 AM   #8
Otto Mattik
The nut on sway bar link was 15mm(wrench size). Found a beefier 17mm nut/bushing/bushing washer, in parts hoard. After some lifting and fussing it's back together.
Thanks for all input & advice
Old 07-29-2017, 02:01 AM   #9
They're 17mm hex early and 15mm hex late.
Threaded M 10 x1.5 if I had to guess.
Old 07-29-2017, 02:07 AM   #10
Otto Mattik
Yep, I noticed that. Good advice. Going thru suspension, working out the bugs, thanks.
1992 240 Wagon Lesjofors HD frnt sprngs/ Bils HD, Swedish 14mm rr sprngs, IPD 25mm bars, IPD pnhrd, oe exhst set up, VX
* The sway bars, panhard bar, vx, & Bils were on car when I purchased it. I removed the lowering springs, & likely will replace the rr bar w/ 21 or 19(?). The Bils shocks were trashed, & considering another set. The struts are fine.
Old 07-30-2017, 01:39 PM   #11
A 242-244 21mm 240 turbo rear bar would be best on a wagon with a 25mm IPD front bar.
Old 07-30-2017, 05:26 PM   #12
Otto Mattik
Sounds good. I still haven't decided if I'm keeping the 25 up front ? Considering the terrible roads up here & already running HD springs, she rides ruff unless loaded to the hilt. I'm even considering going to 13mm rr springs (intersting the 14's are NLA, currently) ? Likely hang onto the 14's in the event I ever get around to mounting trailor hitch (?) thanks again !!
Old 04-21-2018, 03:51 PM   #13
Centsableone
SNAFU - BOHICA
I installed some 23/21 sways and checked the thread on the link and it is in fact M 10x 1.5 !
Old 04-21-2018, 05:33 PM   #14
lummert
lummert's Avatar
The nuts are self locking.
Old 04-24-2018, 05:22 AM   #15
Otto Mattik
Thanks lummert
