Old 02-21-2018, 11:21 AM   #26
SquareD
An Anomaly
SquareD's Avatar
Originally Posted by PromiseRing View Post
Green 5 speed with **** paint, iPd sways, B cam, ice cold ac, hot heat, a few poly bushings, too much rust, etc. great when it’s not 90% humidity.
You're quite the salesman.
Old 02-21-2018, 11:25 AM   #27
I don't follow, but sure why not!? I use it on certain airbag recalls on the connectors per the directions. It can only help. It will also help keep things water tight. I think there was a Volvo bulletin back in the day instructing techs to smear it on the ECU connector on a 740. Moisture and vibration causes fretting on terminals.
I would pull the ignition coil wires and lightly clean the terminals. Do same with all the fuses. Possibly the fuel pump wiring too.
Come to think of it, spark plug wires are also suspect. My 1990 240 wouldn't start/misfires in high humidity in the mornings and plug wires were shorting. Spray baking soda water on them at night and inspect for arcing.
Old 02-21-2018, 11:41 AM   #28
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
$3k firm no low baller. I KNOW WHAT I HAVE
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
PromiseRing is online now   Reply With Quote
Old 02-21-2018, 11:45 AM   #29
PromiseRing
I inspected in the dark last night (without spray) and couldn’t see any arcing. Gave everything the good old wiggle test but no change. Swapped out a spare cap and rotor that I have but no change. Wiggle o2 sensor wiring and no change. Wiggled ECT, IAC, TPS etc no change. The o2 heater wires on the firewall were kinda crusty so I used a flat blade to clean them up. No change. And as stated above I’ve swapped wires with a used set (I know, I conclusive) and the results are the exact same. I also pulled ignition coil wires and reseated all spare connectors. Didn’t clean them just reseated them.
Maybe I will spin some fuses today
Old 02-21-2018, 12:14 PM   #30
PromiseRing
It rained last night a lot, but temps got low. 26F this morning and they say 90% humidity but I doubt it with how cold it is. Anyway, car started and ran fine today albeit the typical B cam cold idle for 30 seconds. No bogging down.
Now we wait to see if the 7 gives us trouble.
EDIT: https://www.reddit.com/r/askscience/...reezing_point/
Alright well I don't really get this too much but it definitely *feels* less humid than the torrential downpours we've been having.
Old 02-21-2018, 02:13 PM   #31
PromiseRing
Issues came back after class. At idle, when it’s running like crap, the exhaust reaks of fuel. That leads me to believe it’s receiving sufficient fuel pressure, but not sufficient ignition. Maybe I’ll swap coils or have a look at the powerstage.
Old 02-21-2018, 03:51 PM   #32
PromiseRing
Anddddd 7 wouldn’t start whe she needed to drive to an interview. Man a loan on a Camry sure seems tempting right now.
Old 02-21-2018, 03:56 PM   #33
Send her my serene condolences...
Again.
Old 02-21-2018, 04:06 PM   #34
You need to figure out if it's a no spark or no fuel. Powerstage could be getting wet. Or is this Regina?
Old 02-21-2018, 04:15 PM   #35
PromiseRing
Lh2.4. We’re just both so ****ing busy with school and stuff otherwise it wouldn’t be a big deal. I will see if it’s lack of spark or fuel later on. I’m guessing spark but we’ll see.
Old 02-21-2018, 06:00 PM   #36
PromiseRing
Powerstage was wet. Dried it and cleaned all the white **** off with a wire wheel. Cleaned the back surface where it mounts to the fender. Cleaned pretty much everything.
Still no change.
Edit: I understand that thermal paste is important in heat transfer, but i didn’t know if there was a grounding issue or something. I’ll try to get some thermal paste for the powerstage soon.
Old 02-21-2018, 07:00 PM   #37
Lando
Arthur Digby Sellers
Lando's Avatar
What kind of shape is your wiring harness in? Even the late non-biodegradable ones can have issues this late in the game.
Have you gone through the LH2.4 green book trouble shooting steps? It only takes about an hour or so to check everything fuel and ignition.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is offline   Reply With Quote
Old 02-21-2018, 07:21 PM   #38
PromiseRing
Wiring harness appears to be perfect everywhere. Haven't ran through all those steps yet though.
Here is a video of how it acts on cold starts. Once it's warmed up it seems fine. I beat the hell out of it burning through second gear. Pulls all the way to limiter when warm
Old 02-21-2018, 07:25 PM   #39
TurboDenny
Why am I here?
Have you pulled the plugs to see what they look like?
Instagram: @itstotesdenny
Old 02-21-2018, 07:36 PM   #40
PromiseRing
Have not. It just seems like a super rich condition until warm and then it clears up. If we ever have some clear weather without humidity I'll see if the issues persist.
Old 02-21-2018, 08:00 PM   #41
lummert
lummert's Avatar
Coolant temp sensor?
Old 02-21-2018, 08:11 PM   #42
PromiseRing
Replaced with OE Volvo like a year ago I think
Old 02-21-2018, 08:24 PM   #43
PromiseRing
Wow. These either look lean or they look okay. Definitely not rich like i thought
Old 02-21-2018, 10:50 PM   #44
PromiseRing
Just installed a pink label 561 ecu and the problems are gone. What the ****
Old 02-22-2018, 12:20 AM   #45
PromiseRing
Now with the 951 ecu the issues are gone too. Tomorrow morning will bring more conclusive results.
Old 02-22-2018, 04:54 AM   #46
Otto Mattik
Otto Mattik's Avatar
Rust not goodly but I hope it serves you well in any case
Originally posted by Jack
_________________________
Old 02-22-2018, 10:27 AM   #47
Toss the old ecu back in there and see if acts up again. Could just be fretting on the terminals and the plug/unplug cleaned it up. Maybe not.
Modern cars have much smaller terminals than these old tanks. I commonly have to install new terminals and run fresh wires on circuits that act up.
Old 02-22-2018, 02:07 PM   #48
lummert
lummert's Avatar
Is your car supposed to be running non-resistor plugs?
Old 02-22-2018, 02:21 PM   #49
PromiseRing
^ probably should be running BPR6ES instead, but IIRC the auto parts store didn’t have them at the time. AFAIK, that should cause any issue right?
Also, 951 ecu is back in and the issuenis gone for now. So maybe I just needed to reseat the connector. We will see if it stays good though.
Old 02-22-2018, 03:39 PM   #50
PromiseRing
Issue slightly came back on the way to class. I’m gonna plop in the pink label 561 one indefinitely and deal with the cel, we will see if the issue persists, again.
