Old 08-06-2018, 12:30 AM   #226
BR1CKHOUS3
I like the tuna here
BR1CKHOUS3's Avatar
Water pump and E fan are on
We don't do it for the glory.
Originally Posted by SlowRide View Post
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 08-07-2018, 08:49 PM   #227
BR1CKHOUS3
BR1CKHOUS3's Avatar
Pulled the Efan out to make some clearance for the water pump pulley
Old 08-08-2018, 12:35 AM   #228
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Wait, you killed another one? Seriously dude, if that's the case you need to check the control circuit on it. They aren't a common failure fan...
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 08-08-2018, 01:14 AM   #229
BR1CKHOUS3
BR1CKHOUS3's Avatar
Nooo same fan, just had to trim the mounts I made for it to make everything clear. My roommate wired it up with a new relay
Old 08-08-2018, 10:33 AM   #230
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Whew, I was gonna say.....that would be bad if another died. lol
Old 08-08-2018, 09:07 PM   #231
BR1CKHOUS3
BR1CKHOUS3's Avatar
Brake booster repair attempt #1 Not sure if the new booster will fit. I'm working on eliminating this (seemingly) one year only booster that has a weird adapter on it
Old 08-09-2018, 04:23 PM   #232
BR1CKHOUS3
BR1CKHOUS3's Avatar
The brake booster swap was mostly a success This car really is unique in a lot of ways that aren't fun for maintenance Turns out the rod that interfaces with the master cylinder is different on this car, hence the weird spacer that looks OEM to me If I change to a different master cylinder I'll have to swap the rod back again. Wasn't a big deal, but I think I will write an article on this phenomenon and my solution to save someone else from this headache :P
Old 08-09-2018, 06:50 PM   #233
BR1CKHOUS3
BR1CKHOUS3's Avatar
Swapped out the broken glove box and lower trim for a fresh one from a 940. Learned that the 940 glove boxes are smaller inside. My owner's manual doesn't fit!
Old
New
Old 08-09-2018, 07:53 PM   #234
gsellstr
Vintage anti-ricer
gsellstr's Avatar
BTDT on the master. 90's really are a PITA.
Old 08-09-2018, 11:17 PM   #235
BR1CKHOUS3
BR1CKHOUS3's Avatar
I really wish I had asked you about it before Figuring it out feels good, just took a while.
And in true fashion, I fix a bunch of things on the car and the passenger front window stops working
On the bright side I put in all the lighted window switches. The little things really keep me motivated I think there was a thread about making the auto function work on the driver's window.. anyone remember that?
Old 08-10-2018, 09:49 AM   #236
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Requires some relay trickery to make it work.
Window issue...did you get the right switch in the right spot? Swap the left and right, the right side window won't work. Again, BTDT, traced my steps a couple times before I caught it.
When I was dealing with the master I ended up finally hitting up a forgotten parts supplier in town that actually knows **** is different so he was able to get the right master without dicking around with it. Then my booster went out a year later, back to finding one with the correct orientation. JY unit over reman for that so I could get one that didn't leak out of the box. lol
Old 08-10-2018, 12:01 PM   #237
BR1CKHOUS3
BR1CKHOUS3's Avatar
I had no idea they were side dependent. How very Volvo The window did work at first and then quit after the first test drive. Weird
Old 08-10-2018, 12:27 PM   #238
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
You'll need the wiring and auto-down relay from an 850 to make that work.
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 08-10-2018, 03:03 PM   #239
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Only the fronts are side dependent. Check the pinout on the bottom, the driver side has a pin the passenger side doesn't.
Old 08-10-2018, 09:22 PM   #240
BR1CKHOUS3
BR1CKHOUS3's Avatar
Right on, thanks! I knew it was some OEM concoction If someone can find the original discussion thread they get +1 internets
I popped it apart and now I see what you mean
I say this every page of this thread, but you guys and your knowledge are a huge help. TB is still good people
Coolin' in the garage:
Old 08-11-2018, 01:27 AM   #241
+Kardboard+
http://forums.tbforums.com/showthread.php?t=19742
https://www.google.ca/search?q=850+a...hrome&ie=UTF-8
Old 08-11-2018, 08:51 PM   #242
BR1CKHOUS3
BR1CKHOUS3's Avatar
Right on, thanks Kardboard!
So I fix the window switches (thanks Gary) and then the cruise control quits damn car. The diaphragm and line look fine..does the CC have its own relay I should check? Going to work through this article for now:
https://www.volvoclub.org.uk/faq/CruiseControl.html
Old 08-14-2018, 11:21 AM   #243
BR1CKHOUS3
BR1CKHOUS3's Avatar
Old 08-14-2018, 07:14 PM   #244
BR1CKHOUS3
BR1CKHOUS3's Avatar
Ordered a 16" low-pro Spal
Stopped by Kruse/Lucas and picked up a valve cover gasket. Parked next to my 'twins"
Old 08-15-2018, 08:12 PM   #245
BR1CKHOUS3
BR1CKHOUS3's Avatar
Oil change this morning. Spent the early afternoon deciphering the different types of window switches. 3 different switches shown in various stages of disassembly
Old 08-16-2018, 06:58 PM   #246
BR1CKHOUS3
BR1CKHOUS3's Avatar
After a lot of staring at the switches, I decided you can just solder the switch as I did here. The solder nearest to the bulb is where it needs to be done. The solder to the left was just to reinforce a connection that looked near breaking. I'll make a little write up about how to make them work in the driver's door. Thanks Gary for pointing out the difference! I'm no electrician so my solder work will improve over time. Time to start looking for some 850 auto window relays
Old 08-17-2018, 05:07 PM   #247
Janspeed
about the cruise control: I remember retro fitting a complete set into my 940lpt.
in a CC equiped cars there is a cut-out (vacume?) switch below the brake pedal.
In a manual trans car the clutch pedal also has a second switch below the clutch pedal.
Both switches can and need to be height adjusted in such a way that they only break contact/vacume whenever the pedal is pushed in.
In an earlier post you mentioned that you replaced the brake booster + the pushrod between pedal and mastercylinder. maybe one of those switches is no longer adjusted correctly because that pushrod effects the resting position of the brake pedal. Making the CC system inoperable.
solution: re-adjust cut-out switch on the brake pedal. Let us know if that fixes the CC.
picture of the setup in a 850 but in a 740/940 it's very similar:
https://s14-eu5.startpage.com/cgi-bi...ffebc57ee9f3b6
Old 08-17-2018, 10:08 PM   #248
BR1CKHOUS3
BR1CKHOUS3's Avatar
Every time Janspeed posts in my thread I think "Oh great...what did I do wrong?" I understand what you're saying about the switches breaking contact. It will be until Tuesday before the car and I will have any significant down time. Honestly, thank you for sharing! I am sure you are helping more than just myself
Old 08-17-2018, 10:09 PM   #249
BR1CKHOUS3
BR1CKHOUS3's Avatar
This also showed up today
"Omg it's so nice to meet you, I'm a big fan!"
Old 08-19-2018, 10:05 AM   #250
BR1CKHOUS3
BR1CKHOUS3's Avatar
Heading to Euro Sunday August meet today
