Old 02-01-2019, 11:29 PM   #1
MisterBLC
Default 7xx/9xx Heater Valves?
Ok, sick of these crappy plastic parts! Heater valve split and left my wife stranded on the side of the road. Thankfully the engine didn't overheat but I'm looking for a solution that doesn't suck. Any recommendations on a replacement heater valve that isn't plastic junk?
MisterBLC is offline   Reply With Quote
Old 02-01-2019, 11:50 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
https://forums.tbforums.com/showthread.php?t=246617
I have one of these valves in my 744t, 944 and 945t and I have had zero failures in 10+ years and that is in 110+deg AZ heat.
Old 02-01-2019, 11:50 PM   #3
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
It's winter? Avoid the problem? IDK, don't bother just put a sturdy male-bale barb on it and forget about it? That thing is only used on the max a/c / heat all the way off anyway?
How PSI a stock can support?
Always Be Crushing!
Old 02-02-2019, 01:03 AM   #4
MisterBLC
Yeah definitely have it bypassed for now...I'm thinking ahead for when my wife wants colder AC in the summer
Old 02-02-2019, 11:11 AM   #5
Ursan
Bored Member
Ursan's Avatar
What they said.
I once used a straight through deep 13mm socket just to "get me home" (for the next 4 months).
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 02-02-2019, 11:49 AM   #6
moustacio
No experience with it but I've been looking at AC Delco 15-5320 when I go to replace mine in the spring.
moustacio is offline   Reply With Quote
Old 02-02-2019, 12:13 PM   #7
soclosenotnear
Been there and done that; my old lady had our newborn in the car, but this is best ...
Old 02-02-2019, 12:53 PM   #8
iHateVolvoPeople
This is what I used in my 7 and it works great.
https://www.amazon.com/Motorcraft-YG.../dp/B000C5DZOG
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 246k
99' Camry A140E.
96' Camry wagon, v6 auto
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 02-02-2019, 01:26 PM   #9
Dirty Rick
Dirty Rick's Avatar
Thanks!
Old 02-02-2019, 02:12 PM   #10
oldnfast
The yg-136 is great,been using them for years.the first thing I do with a new to me 7/9 series is replace that valve. Consider it a wear item.
oldnfast is offline   Reply With Quote
Old 02-02-2019, 04:07 PM   #11
gsellstr
gsellstr's Avatar
No relation to what mode the HVAC system is in. It's controlled strictly from the temp control side of things. Once you crack it off the full cold setting, the valve opens.
Swapping to the one TLAO posted functions the same way, except it allows coolant flow out of the back of the head even when you don't have the heat on. It also allows for more coolant flow thru the core so you actually get a little more heat in the dead of winter.
I've had that style on mine for several years as well, no issues.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 02-02-2019, 04:29 PM   #12
955IsAlive
Winning
955IsAlive is offline   Reply With Quote
Old 02-02-2019, 06:14 PM   #13
iHateVolvoPeople
Me too! Bought a 7, it started leaking coolant like 1 month later. Replaced with ford valve and still going strong.
