Old 02-26-2019, 10:45 PM   #1
89_740Turbo
89_740Turbo's Avatar
Default Questions about putting different bolt pattern wheels on 740 because im dumb
I'm dumb when it comes to wheels. I always play it safe and force myself to be 'satisfied' with the elusive 5x108 bolt pattern wheel.
Well its a new year and I'm gunna stop being a puss when it comes to wanting to put new wheels on.
I found a pretty cool set online. I like them a lot. Id like to buy them eventually.
Details of them are as follows: 17" x 7.5", +38 Offset, 5x114.3 Bolt Pattern, 73.1mm Hub
I know I will need 5x108 to 5x114 adapters BUT what I don't know is, is there a thickness of the adapters I need. Is the hub diameter too large or small. I don't know anything about wheels!
Thanks in advance
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 02-26-2019, 10:53 PM   #2
2turbotoys
Have you seen me?
2turbotoys's Avatar
I, and many others, have used 25mm spacers in front, or all the way around, and 32mm in the rear. Works great! I don't remember the hub diameter, I didn't use hub centric spacers, which means you need to be very careful putting them on, hand tighten every other lug nut until you can't anymore, then use the sockets.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 02-26-2019, 10:58 PM   #3
89_740Turbo
Basically meaning the wheel itself isn't sitting on the hub at all and only being fitted to the car by the lug nuts? Oooof
Old 02-26-2019, 11:03 PM   #4
2turbotoys
Have you seen me?
2turbotoys's Avatar
Yup, it withstands a lot of punishment, not V8 torque probably but anything the normal B230FT puts out, and the adapters are cheap. I did a ton of nasty burnouts on them with no problems. That tiny little lip is only really centering the thing anyway. I understand if your not comfortable with it, gotta be very confident in your install and its fine.
Old 02-26-2019, 11:07 PM   #5
2turbotoys
Have you seen me?
2turbotoys's Avatar
My spare set of 25/32 mm adapters, got them on Amazon I think
Old 02-26-2019, 11:10 PM   #6
89_740Turbo
Awesome, thanks for the info. One more question: Do they sell hub centric adapters or do they not exist. I'm about to google now but figured id ask anyway
Old 02-26-2019, 11:17 PM   #7
2turbotoys
Have you seen me?
2turbotoys's Avatar
H&R sells hubcentric in 5x108 to 5x108, in 25 mm only. I don't know if they have other bolt patterns, I have only done the 5x108 route. Expect to pay at a good bit more for hubcentric, I believe the last set of 32mm spacers (left above pic) was just over $100 for 4 spacers, I thought I was getting 2 and was surprised when 4 showed up.
Old 02-26-2019, 11:51 PM   #8
89_740Turbo
So the center bore on the wheels is 73.1 but the bore of a 740 hub is 65.1 and I just found these - https://www.ebay.com/itm/4-Aluminum-...S!-1:rk:7:pf:0 - so I'm going to go out on a lim here and say this is what I would need to use with a 5x108 to 5x114 adapter?
Old 02-27-2019, 12:00 AM   #9
thelostartof
unbalanced chemical
thelostartof's Avatar
Do **** right
http://www.motorsport-tech.com
Old 02-27-2019, 12:20 AM   #10
89_740Turbo
Originally Posted by thelostartof View Post
Ooooo thanks for the link!
If I were to order custom ones, what should the stud size be. I'm thinking 12-1.5
Old 02-27-2019, 08:12 AM   #11
Ilvmetal
Spend now save later
1973 142 Turbo 8V build
1988 740 16V money pit
2004 V70R Wife's DD
2017 S60T5 Pole star ecu flash (still slow)
At any given time I have to many projects but not enough Volvos...
Ilvmetal is offline   Reply With Quote
Old 02-27-2019, 05:24 PM   #12
Default wheel fitment
here are some companies that make wheels you won't need adapters for. Browse them a bit.
https://www.hrewheels.com/?gclid=EAI...SAAEgJbLPD_BwE
https://www.comp.co.uk
https://www.rimstock.com
Not cheap but they make very nice wheels. Your stock offset is 25mm on the 740T.
Old 02-27-2019, 09:56 PM   #13
89_740Turbo
So I found some wheels that I really really like - https://www.performanceplustire.com/...ure-3/ws:16x8/
I now stock 740 offset is +25mm. With these wheels being +20mm offset as well and having a 8" width, what width adapters would I use to have these flush or still under the fender
Old 02-27-2019, 10:05 PM   #14
2turbotoys
Have you seen me?
2turbotoys's Avatar
Doing it right and spending now to save later both mean "don't use spacers or adapters, get the proper wheels that fit", they won't pass inspection in many states when they are over 5mm, for a couple reasons, a large one is you can't tell if the spacer is coming loose until its very loose and you get vibrations, hub centric doesn't help with that problem. But ya the more expensive hub centric ones is the lesser risk, especially if you don't want to take the time to properly center the cheaper ones.
Spacer thickness answer is still the same for a 9" rim and 25mm will be fine
Old 02-27-2019, 10:26 PM   #15
thelostartof
unbalanced chemical
https://www.rimsntires.com/specspro.jsp
This should give you an idea on tire sizes and offset.
Old 02-27-2019, 11:06 PM   #16
89_740Turbo
NJ doesnt require inspection for cars older than 20 years so I luckily dont have to worry about that. 25mil spacers all around with a 9" wheel, math wise when I did it, make it seem like it would be protruding way out of the wheel well lol that's the only reason I ask
Old 02-28-2019, 06:19 PM   #17
Ilvmetal
if your planning on Mucho HP trust me, adapters are a no no. Better off drill and fill some ARE 398s, thats what I did and it ended up costing the same as adapters.
I have a set of barrels you can have for $200 bucks if interested.
Old 03-01-2019, 04:16 PM   #18
89_740Turbo
That's probably what I am going to do - just bring wheels somewhere to get drilled. I've been researching and researching the hell out of different setups I could possibly use for my 740 but between the stock 25mil offset and the rest of the wheel offsets out there plus having to use spacers, I don't know if anything will work.
Old 03-01-2019, 04:26 PM   #19
RvolvoR
16s aren't worth even buying anymore....there are hardly any decent tire choices in 16. Go 17s or 18s.
Old 03-01-2019, 04:34 PM   #20
89_740Turbo
I am running 17s at the moment. They came with the car so they aren't "me". If that makes sense.
Ultimately, what I am trying to figure out is what combinations can I go with that will work on a 740. See picture below
I need to figure out what wiggle room a 740 has. You see where the 2 red lines intersect, horizontally than vertically? I need to figure out what the distance is of the horizontal line so I can determine a few things.
1. What offset wheel is ideal
2. What size mm wheel adapters do I need to use
#2 will of course be determined by #1 since the adapters will push the wheels out a little more. I am seeking a wheel that has a lip - something like a BBS but doesn't have to be one.
I have been trying to figure out how I can fit these wheels onto the car.
17x8.5
Offset: 35 mm
Backspace: 6.125"
As well as trying to figure out if I could fit these, which I like more
17x8.5
Offset: 15 mm
Old 03-01-2019, 05:51 PM   #21
cwdodson88
ok so take the wheels off, hang something heavy (plumb bob) from a string attached to the fender and use a measuring tape?
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-01-2019, 06:13 PM   #22
Ilvmetal
He's right.
Like magic...here is your actual car with those 16" in rims.
17s are good but 18" are seven sexier.
I'm running 18" R pegs on my current 740 and it's a perfect fit
Old 03-01-2019, 09:14 PM   #23
89_740Turbo
[QUOTE=Ilvmetal;5922509]He's right.
Hey! That's where the cars rain and wind deflectors went! LOL
Old 03-11-2019, 08:20 PM   #24
DrZiplok
DrZiplok's Avatar
What he said - motorsport-tech / Adaptec know their stuff, and this approach unlocks wheels that simply aren't available with the sort of offsets you'd otherwise have. Pick a vanilla PCD like 5x4.5, do the offset math to get you to et40-ish, and voila, you look like a Mustang.
DrZiplok is offline   Reply With Quote
