Old 05-05-2019, 07:51 PM   #1
dirtlip
Default Front Wheel Stud
Hey all!
So, we have a new-to-us '92 NA 240 Wagon. One of the wheel studs was stripped, so hammered it out and realized the ABS tone ring is in the way of removing it. It's SO CLOSE to clearing the ring, but there you have it.
Any way to replace it without removing the hub? Figured someone here would have the right approach.
Plan for installing the new one is to make sure the splines are aligned, make extra sure it's going in straight, and to put a nut & two fender washers on the stud with lots of moly lube and use an impact to suck it in (or if that feels dicey a long breaker bar).
Thanks!
~j
dirtlip is offline   Reply With Quote
Old 05-05-2019, 08:55 PM   #2
84B23F
84B23F's Avatar
Sure...remove whole assembly...use hydraulic press to remove, and install...clean bearings, etc., repack them, and install with new seal/etc.
Old 05-05-2019, 09:02 PM   #3
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Wheel studs and bearings are cheap compared to what can happen when they fail. If one failed, replace them all.
Old 05-06-2019, 12:13 AM   #4
towerymt
the real Towery
towerymt's Avatar
I would draw it in by hand, but with lube it shouldn't get too hot with an impact. I'd just want to feel if it "felt right" when pulling the stud in.
Old 05-06-2019, 12:30 AM   #5
^+1
And re-check the tightness of the lug nut a after taking it for a short drive, and again after a day or so.
Old 05-06-2019, 12:40 AM   #6
Jack
junkman
Jack's Avatar
Pffft all you need is 3...
Old 05-06-2019, 10:16 AM   #7
Stiggy Pop
Stiggy Pop's Avatar
I just did 20 long studs and front/rear wheel bearings on an ABS car this weekend, you'll have to take the front hubs and tone rings off.
I did not want to sit there and impact 20 studs in place, so did stud install operation on the press. I liked that smooth control much better than hammering on the threads with the gun.
'79 242
943 pickup
Old 05-06-2019, 11:33 AM   #8
moustacio
This will hopefully answer your question:
https://www.brickboard.com/FAQ/700-9...heelStudRepair
240 guys should be able to weigh in if its the same procedure, but I would imagine so.
moustacio is offline   Reply With Quote
Old 05-06-2019, 12:40 PM   #9
dirtlip
^ YES!
That's exactly what I was looking for:
"If you have an abs sensor wheel (looks like a gear with flat cogs) on the front hub you will have to grind one side of the new stud's flange to get it in. You'll have to use a grinding wheel. This wheel is stamped steel and you would destroy it if you try to remove. Then put a nut on the stud and crank on it till the stud seats itself into the hub. You won't have the same problem with the rear since the abs sensor is in the differential."
Thank you!
Old 05-06-2019, 01:43 PM   #10
84B23F
84B23F's Avatar
^ YES! That's exactly what I was looking for:
It should only be performed under a shade tree, if the "right approach" is seeked.
Old 05-06-2019, 01:45 PM   #11
You can remove and reinstall the ABS tone rings without a problem, you just need to be careful.
I have done it dozens of times.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 05-06-2019, 02:20 PM   #12
lummert
lummert's Avatar
Heat the tone ring, remove tone ring, replace stud, heat tone ring, install tone ring. It wasn't that difficult to remove the tone ring from from an 88 765 ABS hub and install on a 740 non/ABS hub for my 88 765.
lummert is online now   Reply With Quote
