Well, it was just a matter of time.
This afternoon the rubber part of the crankshaft pulley/vibration damper totally failed. The inner alternator belt cut into the lower timing cover to boot. Honestly, I shouldn't complain too much. The pulley failed as I was backing out of my driveway for I wasn't stranded miles from home.
I'll have to replace this over the weekend as this is my daily drive. I'd appreciate advice on how best to get this pulley off. First of all, what is the size of the nut on the crankshaft? I'll probably have to buy a new 1/2" drive socket for this. I do not have IPD's handy dandy pulley holder or access to air tools. The Haynes manual suggests jamming a screwdriver in the flywheel teeth, after removing the starter, to lock the crankshaft. The 240 has a M46 transmission - would putting it in 1st gear with the hand brake on hold it?
Looks like I'll have to buy a pair of new alternator belts - I replaced the power steering belt last weekend - perhaps re-tensioning the A/C compressor belt may have contributed to the demise of the crank pulley. I suppose now would be a good time to replace the timing belt too, luckily I have one in the garage.
Any suggestion would be appreciated
