Marvelous3
Who engineered this?
- Nov 12, 2002
- Atlanta
Over the weekend I've got plans set up to fix my coolant temp sensor that has had me running rich for oh about six months. I was thinking I maybe should put new plugs in it as the ones in there now are probably loaded with carbon deposites from the richness.
Which brings me to wonder what plugs you guys would think would be good? I was thinking of going with maybe a hotter plug?
Engine is more or less stock '90 b230f with b cam. I pulled the pre-heat hose out and epoxied the pre-heat hose hole closed and pulled out all of the foam and other **** that was in the air box.
