Hi all,
I've been on a conquest getting my driveshaft carrier bearing replaced for the past few weeks. I farmed out getting the bearing replaced, and the first time, the shop destroyed the dust cover in the process, and I had to wait a few weeks for a replacement to arrive from Sweden. Yesterday, I finally brought the driveshaft back to the shop, dust cover in hand. I was at work when they called, so my girlfriend picked up the driveshaft from them, and I got home after they had closed for the day.
Come to find out, they ignored the marks I provided to line up the splines, and seemingly pounded it in as best they could. I could not pull the two parts apart to realign them, ended up bringing it back to them, and they used an air hammer to get them apart. It appears '93 driveshafts for 240s may be keyed.. I saw a few mentions of 900 series driveshafts being keyed in '93 on, but that practice may have made it's way into 240s near the end.
There was some light scuffs made to two of the splines, but luckily it still fit together smoothly when lined up correctly. Unfortunately, after getting the shaft back together with a new rubber support, I noticed a clanging when handling the driveshaft..
It appears something has broken free in the tube. Has anyone heard of this happening before? The object is too large to be removed, and clangs around when rotating the shaft. Aside from this potentially throwing off the balance of the shaft, I imagine it's going to make a racket going down the road. Am I in the market for a new driveshaft at this point?
