BB-Q
- May 30, 2005
- Costa del Fylde
dammit- With all that movement between Lincolnshire and Cumbria couldn't you search for space within your hearts to help a poor man (in Lancashire) out with a free 245?
Well it depends on what you do and don't count. One of those is being scrapped, and another is either being sold or scrapped fairly soon. Depending on what I get rid of in the next few months, it may go down as low as 5. I'm contemplating a much needed purge...
cheers
James
ive got a delivery coming from cumbria next weekend , get your orders in .
Free or really, really, really cheap 245 please!
You may be able to put a spacer under the driver side engine mount to give you a little more room to play with ,and also posibley cut down/offset the mounting holes on the passanger side ,just watch the sump clearance .A 1/4" to 3/8" thick spacer may make all the diffrance.
to fitting the down pipe.
Regards Roger
needz moar pictars
if you have originals in none bent/stretch cond, decent machine shop be able to make some up?I am having real trouble finding replacement Con rod bolts.
