centason
Autogestion
- Jan 20, 2013
- Ft.Mill, SC
*mental pic* = not pleasant
I like that you placed the ground on the threads of the spindle... smart!
Did that to prevent slag landing there an messing up my threads what's the big deal
Your very lucky if that alone doesn't mess up the threads. You'll learn with time, spring loaded ground clamps can mess up machined surfaces and threads very easily, that would be a easy write up at work Lol. Its veey comon for spring loaded crappy grounds to slip or move just a tiny bit leaving small arc's on material destroying its threads or machined finish.
hub nut goes on fine no biggie lol. you guys are just nit picking now. I realize it can arc that's why I didn't try and move it while welding lol wtf.
im doin some bracing today ill see wha tyou guys think when im done. yeah I know ppl are just trying to help but it got out of hand and now its just irritating.
All the angry. I need to look at those Z coil overs though.
Just though someone should mention that running "flush" wheels will push the contact patch (and thus vertical reaction load) farther out from under the strut and increase the bending moment on that joint.
I'm sure I've mentioned that I sectioned the coils on my 240z. I can try to find you pictures.
and at asher idk how many times I gotta say this I told you on facebook already im not planning on be slammed im gunna be as low as my car is right now why so much focus on how low I wanna be?
yeah, swedge is slang for swage.Too used to looking at swedgelock fittings...
You actually did say you're going to run it really low. I'm just wondering why you are wanting to run a questionable setup with used coil overs. That's all. You're not really gaining much with this over a nice set of 8610s or something of the like.
I heard there was dick pics and fake based coilovers?
Well, the way I see it is that coilovers for s-chassis cars are very low in cost and very abundant. Also, it gives him camber adjustment. It also seems easier than cutting a strut tube down to run shorter struts.
Like I said earlier, I'm kinda doing the same on my car, but I managed to get weld on strut tubes for mine, and I bought my coilovers new. Even with that my total cost is under $1000. And if I need to get my coilovers rebuilt, I can get that done locally at a good price.
I do agree that if he left a little more original strut tube materal, it wouldn't seem as bad as it would be better braced from inside. Either way, I would like to know how this turns out, and I'll save any negativity until after the finished product.
