Old 12-13-2019, 08:07 PM   #1
Pietercc
Default Towing 145 with 245
I am going to be picking up a 74 145 that has no engine or trans, would I be able to tow it with my 245 with upgraded rear springs and the heavy duty hitch? I know with a dolly it should be no problem, but I don't want to harm the control arms, and I'm unsure if a it could handle a flatbed.
Pietercc is offline   Reply With Quote
Old 12-13-2019, 08:07 PM   #2
Pietercc
Oh, and it has an m47 trans
Old 12-13-2019, 08:53 PM   #3
Tow dolly on the rear wheels with the driveshaft out of the 145 is your best bet.
Or flat tow it from the commando mounts.
Old 12-14-2019, 07:55 AM   #4
Lankku
Lankku's Avatar
Wont be a problem. If I remember correctly, 4th gear is recommended for towing heavy loads and I'd use it. You'll need it anyway, stock engines don't have enough power for uphills on 5th gear.
245 -90 "B6284T"
Old 12-14-2019, 02:29 PM   #5
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Shouldn't be a problem. Towed a 1972 145 with engine/tranny, plus another engine in the back about 50 km with a 242 once. Did fine. Then, did the same about a month later with a 1973 145 behind the same car. Didn't travel as far with that one, but, again, no problem.
@1982_volvo_242_turbo on IG
Old 12-14-2019, 02:32 PM   #6
white855T
Yep. Flat tow it with a tow bar. With engine/trans out, it will pull just fine.
Old 12-14-2019, 03:58 PM   #7
alschnertz
Enough already!
alschnertz's Avatar
Don't you mean "Tow dolly under the front wheels"?
Agree with driveshaft removal.
Not a fan of flat towing.
Old 12-14-2019, 04:08 PM   #8
Obviously.
Andy and Jack have pulled cars all over tarnation many times and never had any problem.
