So I am still trying to track down my intense driveshaft wobble. Major driveshaft wobble and rumble under low rpm as well.
The shifter shakes side to side while at idle and when shifting there is the occasional clunk. I have replaced engine and tranny mounts, ujoints, center support bearing/bushing, all rear suspension bushings, etc.
I can recheck driveshaft balance but marks are lined up.
The one thing I can think of is the tailshaft bushing causing the driveshaft to be "loose" and not straight and true. How can I check play or movement from the cylindrical metal bushing?
The other thing I thought of is the puny spring that supports the center bearing. Last time I checked it the spring was all bent and out of place and this could be causing the wobble and movement. I could look into a heavier duty spring potentially.
My final assessment is that the front shaft could be bent somehow but you cant tell that unless its taken off. The guibo was also replaced.
