Addicted242boost
- Dec 22, 2003
- California
84 240 turbo
A year ago the car would run for about a minute or two, then die. Before that it had issues with acceleration. Replaced fuel pump (in tank) and issue remained. Users here recommended I replace the Control Pressure Regulator (mine has the 2 year 128 altitude adjustment version).
Finally found one in the yard. Window tag said it ran when brought it (it got hit on passenger side), so I figured it was okay (all lines had fuel in them). Install the CPR along with intake manifold and all misc vacuum lines following diagrams in bentley/online.
Car gets spark (tested with coil plug on strut tower)
Car gets fuel (tested cold start injector out of manifold and cranked).
It looks like over the year while my car was sitting my fuel distributor developed a very slight leak as well, but the car should still attempt to start even with that I would think.
Any ideas?
Also, anyone know where to get a new seal or rebuild kit for the distributor?
Any ideas?
