Old 03-14-2017, 12:10 PM   #1
Raimis760t
Default B230 performance cam instal/adjust
Hi, i have instaled KL-Racing T2 cam in my b230ft.
Cam specs:
11.3lift in/ex, 280 duration.
In Kl racing shop i see, that this cam need to be instaled at 2.5mm lift at TDC. Now i am doing that, but thats it 10 degres advancing my cam gear.
Can someone giv some advices?
89" VOLVO 760, B230FT, 16T, big IC, 3" dp and exhaust, 044 fuel pump, custom manifold Up pipe, KL-Racing T2 Cam and Cam gear, DET3 piggy, FPR, Bov, custom intake from turbo to manifold, hidraulic hand brake, welded diff, stripped interior, and.... 268HP 382NM
Raimis760t is offline   Reply With Quote
Old 03-14-2017, 12:19 PM   #2
Raimis760t
That means what i can jump the belt for 1 tooth of cam gear, and set at 0 degres at cam gear ?
Old 03-14-2017, 12:35 PM   #3
How many teeth are on the cam gear?
When you're talking 10deg, is that at the cam or the crankshaft?
Old 03-14-2017, 12:44 PM   #4
Raimis760t
38teeth. 10degrees on my cam gear i said.
Old 03-14-2017, 01:01 PM   #5
Thanks, just making sure I understood you correctly
Advancing the cam by skipping a tooth will gain you about 10deg (9.47 if we're getting technical), which you can do. That's just 20deg of advance when it's referenced to the crank, which is a metric f-tonne.
Give it a shot, and then re-time the cam to stock specs and see how it does power wise if you're not pleased.
Old 03-14-2017, 01:17 PM   #6
Broke4speed
Broke4speed's Avatar
According to KLracing's website, they recommend using 2.5mm lash caps as well. Did you install those?
https://shop.klracing.se/sv/artiklar...8mm-skaft.html
1984 B21T (formerly A), AW71(minus L).
Old 03-14-2017, 02:05 PM   #7
Raimis760t
Yes, lach caps instaled. Bought cam/lach caps/cam gear from KL racing.
Old 03-15-2017, 07:45 AM   #8
Raimis760t
no one instaled performance cam by Lift on TDC?
Old 03-15-2017, 12:44 PM   #9
mikep
The MP
mikep's Avatar
Since I didn't see a degree wheel in the photo, I didn't comment.
Originally Posted by zdriver123 View Post
I hope Churd is Smokey. So much hope.
Old 03-15-2017, 12:47 PM   #10
True.
TDC is nice since you can approximately go off the timing marks and be within a few degrees. Or shove a screw driver or some welding rod into the plug hole and "feel" for TDC. I'm still amazed as how accurately you can do that.
Old 03-15-2017, 12:33 PM   #11
I have, just not on a Volvo. It's a way to double check the cam specs and make sure it's timed properly.
Old 03-15-2017, 02:12 PM   #12
Raimis760t
TDC i "found" from plug hole, yes i understand that few degrees is off. But then i set a cam at 2.5mm lift, the tdc mark is way off.. And if i try to set TDC with cam gear, it equals~10 degres advace at cam gear.
Old 03-15-2017, 02:21 PM   #13
Call or email KL Racing and ask them if that's correct.
Old 03-15-2017, 02:23 PM   #14
OR set it straight up (stock timing), go dyno it. Then set it about 10deg advance with your cam gear and then dyno it again, maybe try it at 5deg advance too. Choose the best setting and live in peace.
Old 03-15-2017, 02:33 PM   #15
Raimis760t
wrote to KL racing, no answers.. waiting
tomorow ill borrow degree wheel for correct measurement.
i tryed to drive on 0 degre on camgear, no torque in low end, after 4000rpm runs great. then i loked at kl racing website about cam lift on TDC, and saw that the cam is much retarded from that number, and now i want to "solve" this question
Old 03-15-2017, 02:53 PM   #16
Have you tried driving it with the cam advanced to ~10/20deg?
Old 03-15-2017, 03:02 PM   #17
Raimis760t
No, waiting for few parts till next week.. And now i have time to play with cam degreeing
Old 03-20-2017, 07:08 PM   #18
dafke
And what's now the best timing for that camshaft ?
dafke is offline   Reply With Quote
Old 03-21-2017, 06:52 AM   #19
Raimis760t
at 0 degrees on cam, no torque in low end, hi revs very good. But then i turned the camgear 4-6 degrees advance - torque came back in low revs and hi revs is very good. waiting for dyno in the end of this week
Old 03-22-2017, 03:18 AM   #20
per0lund
per0lund's Avatar
It´s probably about 4-5 degrees advance at crank, but you have to dyno it to get it perfect.
A half deeegre to much advance and you loose more than, than you would gain if it is set right.
Try with a little more advance than a half tooth at cam wheel, its likely a bit to much, then decrease from there till the engine runs smooth as possible from idle.
Volvo 745 -90 B-230FK , M90, 3,31:1 Eaton diff,-MS3X 83 lbs/hr injectors TD04HL-20T
S60 2,5T AWD
SAAB 9-5 2,3T
Ford Thunderbird LX -95
per0lund is offline   Reply With Quote
Old 03-23-2017, 03:38 AM   #21
Raimis760t
i will take a dyno tomorow or saturday, and try to play with cam gear from 0 to 10 degrees advance, and see the numbers
Old 03-25-2017, 03:21 AM   #22
Raimis760t
Gearbox exploded on the way to dyno, then last time wanted to check AFR on load before.. :D
Old 03-25-2017, 12:14 PM   #23
snailpoweredbrick
snailpoweredbrick's Avatar
RWD Parts for Sale (240,740,940)
http://forums.turbobricks.com/showthread.php?t=243774
snailpoweredbrick is offline   Reply With Quote
Old 03-26-2017, 10:09 AM   #24
per0lund
per0lund's Avatar
Transmission M46 Gearbox and clutch is a well-known limit at 740.
It must have been badly worn down to make it explode though.
Old 03-28-2017, 04:10 AM   #25
Raimis760t
box failled on 3 gear, but no problem, i have M90 laying in garage waiting for a driveshaft
