naterhater
- Jul 2, 2013
- Portland OR
I had been running cut springs in my 940 for a while and decided to go back to a full height stock spring. So I replaced the springs and nothing else. I took out the cut springs and installed a set of new stock springs using the same bushings, hardware, and assembly sequence.
For the first half-day or so this was completely fine. Then after a while the right front started to clunk. Upon further investigation, when the car is sitting on the ground, all 4 corners taking full weight, the RF spring feels loose and is making a horrendous amount of noise over even the smallest bumps. The bottom is seated properly, I didn't lose any bushings or anything, all the fasteners are tight. I even took that corner apart again and made sure the upper strut mount and bearing were all seated correctly.
Since taking it apart and reassembling again the noise is worse. On the left you can reach in and the spring feels tight like it should. On the right you reach in and the top of the spring has room to wiggle, even with the weight of the car on it. This is 100% whats causing the noise.
But what on earth could possibly be the explanation for the looseness!? My gut reaction is to say the rubber piece between the spring itself and the supper strut mount bearing is bad, but then it should have been clunking with the old cut springs. I can't even find that rubber piece anywhere, IPD doesnt carry it or a ****ty knock off, FCP euro doesnt have it, and i have no idea what the part number would be.
Any ideas?
Any ideas?
