2 old for this
Well-known member
- Mar 12, 2018
61 544 has had its choke cable cut,not the housing , the steel wire. How is it replaced?
Thanks for sharing.If it's like the others I've messed with, the metal rod that the knob is attached to is drilled in the center to accept the inner cable part way. There are 2 holes drilled through the side of the rod and the cable is flattened at those points. I've tried to remove the cable by drilling out the flattened areas, but they were very difficult to drill and I bent the rod by pushing on the drill too hard. Even after removing the old cable, attempting to flatten the new one proved to be near impossible. I heated the wire red hot, used a pin punch on both sides of the cable (one in a vice) and still couldn't flatten the wire enough. I don't know what that cable is made out of, but it's tough stuff.
