Well.. I finally got my A cam back into the car this weekend after sending it off to have it graphed at Scotts shop out in the PNW..
(Full camshaft stats thread)
I switched back to re-test and solidify in my mind some of my theories on cam selection.. Mostly dealing with overlap this time.. The K is an awesome cam, dont get me wrong.. But it's got it's downfalls. I had it paired to a 13c for awhile this summer while my GT-35 was broken just before I got the T04S 60-1 and found that it really really hates a restrictive turbine.. REALLY. Swapped it out for T just for giggles and my car stopped loping, was easier to start off.. but it hated life above 3500rpm. I'd bought the A and K together but I'd never driven the A so I threw it in to do some official testing.. It turned out to be my favorite, and it actually kinda got along with the 13g for awhile (didn't get compressor choke as badly)
Now that I've got a correctly sized turbine housing and wheel choosing a cam is quite easy.. Once I put the B250FT back in the car I'll have upgraded to under the bucket shims in the head and I'll probably go to something K16 or larger with 46/40 valves.. I haven't done any rocket science research but I'd like to roll out atleast 350whp by next summer.
So when I pulled the K out and swapped in the A, I noticed some space between my manifold and turbo and one of the studs was loose.. Went ahead and pulled the downpipe and the turbo (thank GOD for V-bands) Found that the manifold was warping again so I went ahead and yanked it before it destroyed another good turbine housing.. After I got it on the bench I realized it had some horriffic cracks AGIAN, not to mention one of the M10 1.5 studs I'd upgraded to snapped off below the surface of the face.. So the whole thing is in the trash right now. I'd prepped up another 90+ to go on the 944SE so I could run a T-3/T-4.. That got stolen, it's being used on the race car until I can build up a turbo header for it..
I also fixed the Innovate and got the sensor back into the exhaust stream.. O2 sensor thread chasers can be a life saver.. Dont do a O2 job without one unless you're welding in a new bung. Did some datalog sessions and found out I'd added a lil too much fuel to my maps when I put on the T04S.. but it was mainly for headroom since I was running blind without any O2 sensor for the last few months now.. Just monitoring the Knock sensor which hasn't triggered an event to pull timing back in forever (good news) But then again with AFR's of 11.5:1 under boost.. why would it!?
Bad news is I got a ticket coming home from work Saturday night about 3am on 95north.. Doing 67mph in the middle lane with NOBODY around.. State trooper says he heard my car over his radio heater and scanner from the right shoulder so he pulled me over and gave me a ticket for improper exhaust.. I find that hard to contest since the car is loud.. but only on the highway.. I guess he was trying to make his quota.. Unfortunately he destroyed my Double shift pay 5pm-2am in about ten minutes. I dont really see that as protecting and serving.. More so just picking on people out trying to make an honest living.
