I?ve had a recent string of bad luck with Elwis valve cover gaskets on a b234 engine. The gasket material has been incredibly hard and cracks while going over the cam caps.
The latest was when one section of the gasket cracked and pushed out, causing the valve cover to crack. Usually I would attribute this to over torquing, but it was done with a nut driver... so that?s probably 3-5 ft-lbs.
So what advice, tricks, or brands of gaskets have you all had good luck with on a b234?
