Old 11-13-2017, 03:54 PM   #1
mossymemedogg
Default Brake Troubles
Hello,
I recently bought a '90 240 DL and the brakes felt fine, fast forward about 3 months we got a bit of cold weather and now the brake pedal is spongy and travels a lot more than normal. The car still stops and the pedal seems to stop at the same place each time (there isn't "creep' once the pedal is depressed and the car is stopped), any ideas what the issue could be? and how to fix it/ how much $ to have it fixed.
Thanks!
mossymemedogg is offline   Reply With Quote
Old 11-13-2017, 04:12 PM   #2
speedn_j
speedn_j's Avatar
Sounds like master cylinder. It'll eventually get worst. You could fix it as cheap as 20 dollars or it you want Volvo parts then it'll be about 100. Easy 30 minute job then bleed the calipers
i'm too sexy for RWD
2000 mb c230 kompressor
2000 ducati 748 45k miles
2004 jeep grand Cherokee overland
1988 volvo 245
speedn_j is offline   Reply With Quote
Old 11-13-2017, 05:05 PM   #3
Booster hold vacuum?
how psi stock can support?
Old 11-13-2017, 10:48 PM   #4
speedn_j
speedn_j's Avatar
If it were the booster wouldn't the pedal be rock hard?
Old 11-13-2017, 11:20 PM   #5
Originally Posted by speedn_j View Post
I'd if was the booster wouldn't the pedal be rock hard?
No the seal gets wet with brake fluid and fails slowly, but it won't hold static vacuum.
Old 11-14-2017, 11:27 AM   #6
mossymemedogg
Thanks for the replies. I'm not sure how to check the booster for vacuum, but looking at the junction block behind the drivers side font wheel, it appears to be leaking from somewhere. I am not sure if the block itself is compromised or one of the lines has a leak, is this a common problem? the junction block is directly exposed to whatever is on the road and it seems like it could pretty easily get corroded.
Old 11-14-2017, 11:41 AM   #7
Carefully pull the white one way valve on the booster with the ~5/8" vacuum hose after it's been sitting for a couple hours.
Yes it's a common problem, typically they leak by the warning light sensor switch.
Old 11-14-2017, 12:36 PM   #8
planetman
planetman's Avatar
Brake fluid leaks at the distribution block can be loose or failed brake lines, but that is rare.
The usual problem is 1 or both of the o-rings on the piston assemblies inside the distribution block are bad.
The seal for the electrical contact does not hold brake fluid pressure. If there is brake fluid in the port for the switch its because a piston o-ring(s) have failed.
Eric
Torrance, CA 90502
