View Poll Results: What motor mounts would you use that's available today
Genuine volvo quality new old stock that's been sitting on a shelf for 25+ years 6 42.86%
New genuine volvo available today but not made like the good old days 2 14.29%
New aftermarket available today, your pick 3 21.43%
New Diesel motor mounts, genuine or aftermarket 5 35.71%
Poly mounts 2 14.29%
Other, then state what it is 0 0%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Old 11-15-2017, 12:52 AM   #1
Brick15
Brick15's Avatar
Default motor mount rubber shelf life
There are not too many options these days with good motor mounts. For this thread I'm referring to a 240 but any other model older than 20 years would be included. I'm curious where most stand on this subject so I'm adding a poll and maybe keep things simple.
My choice would have been the nos genuine Volvo sitting for 25 years but I am highly concerned about the rubber shelf life, I don't know to much about it. Any rubber info helps.
You can choose more than one. Your name will be shown when you select a choice.
Brick15 is offline   Reply With Quote
Old 11-15-2017, 01:25 AM   #2
Cwazywazy
Cwazywazy's Avatar
I'd say go with diesel mounts or cheap ones with a third mount. Poly if you like vibrations.
I don't know what I have
Old 11-15-2017, 07:28 AM   #3
DET17
Reformed SAABaholic
Rubber degrades in the presence of heat, oil, oxygen and I believe ozone. I wouldn't
Fear usage of NOS stock. I think the diesel mounts have all but dried up. I set up a search on eBay for NOS mounts and found some made in Sweden units for good prices. The last 240 set I bought was the IPD heavy duty variety, now in my son's Turbo 245. The driver side will carry the tension load so you can run the "strap" if you are making high torque.
Old 11-15-2017, 04:57 PM   #4
GTJordan
Been here for too long
GTJordan's Avatar
From Volvo- only one side of the diesel mounts is still available. (I think the drivers side is available, but the passenger side is NLA, but I can't remember exactly).
Jordan
80 242- 2.5L, T5, Porsche brakes, short billies and kaplenkhe suspension, trutrack.
Old 11-15-2017, 10:59 PM   #5
Can play the blues
To see what is available if I can't find it in the US. I check gcp.se, cvi.se, and skandix.com. Usually that will show you what is available across the pond. As far as new stuff. NOS is just a constant search until you find it or not.
Personally I like to use the diesel mounts on all my 240s but the last time I put on brand new genuine mounts the left one failed after only a few years. The plate cam off the rubber. I have a stock one on there now and the right side is still a diesel mount.
