Old 06-09-2017, 02:35 PM   #226
Tfrasca
Tfrasca's Avatar
Originally Posted by JPS View Post
yeah its running! sweet.
I also don't have the idle motor fitted (plugged the holes), but cold start are no problem at all. when i cold start the car it fire's right away, and idles at 600rpm. when the engine is hot the idle is at 800.
is your brake booster in a good condition? i have had 4 140s and 1 of them had a good working booster, all the other where shot.
The difference between my hot and cold starts seems bigger than yours. Mine will idle hot at 900-1000 (assuming my GT tach is anywhere near accurate), but it won't even run without the gas pedal on cold start. I should have the hoses hooked up by tomorrow.
My booster is in good shape, in that it holds a solid vacuum with no leaks. The brakes feel decent, but I wish they had more initial bite.
Old 06-13-2017, 10:55 AM   #227
Tfrasca
Tfrasca's Avatar
This is what I ended up with. The intake manifold came out especially awesome, thanks to Noah's TIG skills. So happy with how all of this turned out.
Driving impressions after a few hundred miles and the occasional 8 psi are as follows:
4.30s with any amount of power and an open diff means accidental one tire fire at all times.
The 19t with an open filter and Forge diverter valve is TOO LOUD. I'm hoping the diverter valve is leaking or something, because the constant noise, even when in vacuum is extremely annoying.
I need to add resistance to the gas pedal somehow. It's so light with the Yoshi cable spool that it's hard to drive smoothly.
Case in point: I accidentally went an indicated 125 on my GT speedo.
Old 06-13-2017, 11:11 AM   #228
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Jesus dude, That is such a clean swap. Great work. I can't wait until I can see this thing in person someday.
1980 242 Turbo
Old 06-13-2017, 11:22 AM   #229
Tfrasca
Tfrasca's Avatar
Thanks man. I'll probably bring it to the next couple Cars and Coffees at Canepa, as I work through more issues. You should cruise down for one of them.
Old 06-13-2017, 11:45 AM   #230
oldschoolvolvo
oldschoolvolvo's Avatar
Wow, I appreciate your attention to detail on the swap. Super clean.
-Mike
1998 V70 T5
Old 06-13-2017, 11:49 AM   #231
AndrewNance
Amateur hour!
AndrewNance's Avatar
My gas pedal is the same way but I haven't figured out what I'll do about it yet. I used a 240 pedal in my car. It only really bothered me when I was driving on the highway for like 200 miles. I haven't decided if I should just add some kind of return spring to the pedal or what.
'71 142
'80 245
Feedback
Old 06-13-2017, 12:10 PM   #232
kampman
dunning-krugersquirt
That's a beautiful intake. Nice swap!
1966 220 wagon, Ecotec swap project(?)
1999 S70 manual: #base, 191K
2000 V70R: 135K, deer hunter
2006 V50 T5 AWD 6MT: 121K
Feedback Thread
kampman is offline   Reply With Quote
Old 06-13-2017, 12:12 PM   #233
Tfrasca
Tfrasca's Avatar
Thanks, guys!
Old 06-13-2017, 12:15 PM   #234
Tfrasca
Tfrasca's Avatar
Yeah, I have a 240 pedal and a 960 TB. I tried winding the return spring on the TB tighter, but then it fouls the idle stop and only gives you 1/4 throttle. The only other possibility is to rig a return spring on the pedal. Or pour some dirt into the cable housing.
Old 06-13-2017, 12:23 PM   #235
cwdodson88
I'd run a spring on the pedal, so the 149/240 doesn't have an adjustable spring on the pedal mount already? Interested to see what you come up with.
Swap looks awesome! Great work!
The Build Thread
SVEA - PUSHROD TURBO!
Old 06-13-2017, 01:04 PM   #236
AndrewNance
Amateur hour!
I tried the same thing with the return spring on the TB. How did you get your TPS to point forward like that? Is it reversible and I just don't know? Mine points back toward that curved piece on the plenum and it puts a lot of pressure on the harness/rubber boot thing when it's plugged in.
Old 06-13-2017, 01:04 PM   #237
Tfrasca
Tfrasca's Avatar
Yeah, the 240 pedal has a spring on the pivot, but it's very light. Easiest thing I can think of is a helper spring from the top of the pedal lever to somewhere on the steering column.
Old 06-13-2017, 01:17 PM   #238
Tfrasca
Tfrasca's Avatar
Thanks to Pat's tutorial here, it was super easy.
http://forums.turbobricks.com/showthread.php?t=332120
Old 06-13-2017, 01:30 PM   #239
cwdodson88
huh, the 120 pedal has a spring that sits on a bolt that you crank out to add resistance, any way of getting a block or a bolt or something underneath where the spring rests against the firewall?
Old 06-13-2017, 01:41 PM   #240
Tfrasca
Tfrasca's Avatar
There's no spring on the firewall, it's wrapped around the pivot, perpendicular to the firewall. Although, I suppose I could try to wrap it tighter, like I tried with the throttle body.
Old 06-13-2017, 02:16 PM   #241
cwdodson88
I was just thinking that an adjustment bolt/point under what the spring rests against. So theres one side grabbing the pedal, and the other side rests against something, right, so if you can drill and tap that something and toss a bolt in it, the spring now rests against the bolt, loosen or tighten the bolt and it adjust the preload on the spring.
Old 06-13-2017, 02:18 PM   #242
Tfrasca
Tfrasca's Avatar
Yeah, the adjustment would be ideal. Just not sure how much room there is to tap the plastic pivot housing. I'll have to check it out later.
Fixing the warm running issue is the first priority.
Old 06-13-2017, 02:20 PM   #243
cosbySweater
cosbySweater's Avatar
Those forge diverter valves are super loud with a short intake pipe on the small frame turbos, the stock cbv is even louder. Lol
1979 Volvo 244DL 6.0/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, s366 clone.
1982 Ford Fairmont Futura, 4.8/th400, 8.8, mircrosquirt, 7665 turbo, Project Cheap Thrills
Old 06-13-2017, 02:25 PM   #244
Tfrasca
Tfrasca's Avatar
Damn it. That's what I was afraid of. I guess I'll be making an airbox...
Old 06-13-2017, 02:34 PM   #245
cwdodson88
Instead of tapping the plastic, find a bolt/nut short enough and to fit (drill a hole in the plastic to hold the nut/bolt assembled) and let the spring pressure hold the assembly in place?
Old 06-13-2017, 03:36 PM   #246
Tuff240
240 Ninja
Tuff240's Avatar
Is the intake manifold tumbled or something? Looks really nice. The entire project does.
-Patrick
Old 06-13-2017, 03:38 PM   #247
Tfrasca
Tfrasca's Avatar
Thank you. I just used a random orbital with 150, 220, 320, then Scotch-Brite. Mostly I just wanted to get rid of the nasty marks from the break that bent the plenum.
Old 06-13-2017, 03:44 PM   #248
pat244ti
pat244ti's Avatar
Ive got a spare 240 diesel airbox you can test fit, might fit pretty good
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 06-13-2017, 03:46 PM   #249
Tfrasca
Tfrasca's Avatar
Is it really small? It's very tight in the front corner of the 140 bay.
Old 06-13-2017, 03:53 PM   #250
pat244ti
pat244ti's Avatar
It's reasonably small [sorry if the picture is not]
