Old 11-06-2017, 03:57 PM   #26
speedn_j
speedn_j's Avatar
Originally Posted by ICantDrift View Post
Pretty sure that it's just the temp faker and that I don't actually have an overheating issue
Right but when that board goes bad the needle is usually just pegged. It's odd that it only gets hot in the 5k rpm range.
i'm too sexy for RWD
2000 mb c230 kompressor
2000 ducati 748 45k miles
2004 jeep grand Cherokee overland
1988 volvo 245
speedn_j is offline   Reply With Quote
Old 11-06-2017, 04:22 PM   #27
PromiseRing
We don't even like Volvos
They can be erratic when bad.
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
-94' M-Edition Miata-Stock with a hardtop
Past
-80' 242gt m46-
-92' 940 turbo, got for free, fixed, sold
Feedback Thread
can't replace u joints
Old 11-06-2017, 05:07 PM   #28
Can play the blues
A M cam doesn't make any torque or much hp at 5k rpm.
Old 11-06-2017, 05:24 PM   #29
TWD
TWD's Avatar
Just a thought. Bosch 55 amp alternator current rises with rpms. 35 amps at 2000 rpm, 48 amps at 3,000 rpm, and 53 amps at 4,000 rpm. I assume higher at 5,000 rpm, but my book only shows to 4,000 rpm. Voltages might grow a bit also. The voltage regulator is supposed to keep the voltage steady, but VRs aren't exact and the voltage stabilizer on the instrument cluster circuit board isn't all that precise.
As others have mentioned, it only takes a few minutes to bypass the temp faker board.
TWD is offline   Reply With Quote
Old 11-06-2017, 05:52 PM   #30
ICantDrift
ICantDrift's Avatar
It doesn't make power at any rpm lol
Sam
ICantDrift is offline   Reply With Quote
Old 11-06-2017, 08:04 PM   #31
ICantDrift
ICantDrift's Avatar
Just bypassed the faker board and drove around for a bit. The temp rose to just above half way but stayed there, even after a decent bit of abuse. I think that was my problem but I'll keep an eye on it in the future
Old 11-06-2017, 09:18 PM   #32
PromiseRing
Go hold limiter for 5 seconds or do a burnout.
Either way, neither of those things will cause your motor to get warm. Only after about 45 seconds of 5k rpm burnout did my motor start getting hot.
Old 11-06-2017, 11:47 PM   #33
ICantDrift
ICantDrift's Avatar
Well yeah, but mine showed it getting hot after any redline action at all
Old 11-07-2017, 11:24 AM   #34
PromiseRing
Yeah which definitely won’t cause an overheat if your cooling system is in good order. Go redline her again’
Old 11-07-2017, 11:22 PM   #35
John242Ti
trouserman
John242Ti's Avatar
Engage 1st, then drive around for about 45 seconds or so at 25-30 mph while going up a somewhat steep hill. So, high load, high rpm. Check temperature then. Should still be just above midpoint.
-J
1982 242Ti - black, M46. 1985 245Ti - blue, M46. 1989 745Ti - red, Aw71.
Formerly Blue245Ti, 245GT-Turbo, and, originally 242GT-Ti.
John242Ti is online now   Reply With Quote
Old 11-12-2017, 02:42 AM   #36
Brick15
Brick15's Avatar
If you can or even want to, add a VDO temp guage for peace of mind during your years of ownership
Brick15 is offline   Reply With Quote
Old 11-26-2017, 02:44 PM   #37
bumblebeeman
Sounds like you put in a thermostat that is a bit too hot. I recently had this happen also, routine change of the thermostat, same temp 92C-92C and the old one would hold the needle right in the middle even under heavy load. The New 92C, under heavy load it would get up to 3/4 or 5/8 close to red. went to the Pick N Pull and found and 87C swapped in in and now it is back to middle all the time again... I also like the VDO temp gauge idea and have been gathering some parts for that.
bumblebeeman is offline   Reply With Quote
