Old 11-08-2017, 04:38 PM   #1
ZyreX
ZyreX's Avatar
Default Amazon door & window questions
Hello,
I'm giving my Amazon ('66) a respray at the moment, but have some questions while the car is in parts. I'm not that used to so old cars :P
- How do I tighten the window mechanism (2 doors, front doors)? When I wind it all the way up, it falls down 1-2 cms when I let go...
- Is it supposed to be some kind of rubber moulding/seal on the B-pillar against the door? It might be year-specific in any case..
I'm also looking for a new ash tray, mine's rusted into holes...
'66 Volvo Amazon / P130
'83 Volvo 240
'05 Volvo V70 2.0T
ZyreX is offline   Reply With Quote
Old 11-08-2017, 04:44 PM   #2
cwdodson88
I think I have an ashtray.
The b pillar gets cloth wrapped windlace. Adjust the tension pulley at the bottom until it holds tight to the top.
The Build Thread
SVEA - PUSHROD TURBO!
Old 11-08-2017, 04:59 PM   #3
The window winder mechanism has a clutch to prevent the window from being pushed down. They are handed left and right. Either the clutch is failing or the mechanisms were switched side for side.
Also, make sure the lug that the window hatchet attaches to hasn't come loose from the cable.
Old 11-09-2017, 01:43 PM   #4
ZyreX
ZyreX's Avatar
Thanks both of you, useful information! I think I know which part is the tension pulley, so I'll find somehow to adjust it
Clothed windlace is fitted so I guess that's in order then.
@cwdodson88: If you happen to have in decent shape, would it be possible to purchase it? Note I live in Norway...
Old 11-11-2017, 12:16 AM   #5
northNH
northNH's Avatar
Greetings from New England...
I have a very nice one, won't even need painting if your Amazon were red, that I'll send you for nothing more than a kind word about an American somewhere down the line...
Lots to be embarrassed about over here.
'62 Amazon Blk/red 4Dr '67 Amazon Light green/grn wagon
'69 164 4spd/OD unmolested
'94 MBz E320 Silver/gray wagon '92 MBz 300CE Blk/red Coupe
'86 BMW 635Csi Blk/blk Coupe
northNH is offline   Reply With Quote
Old 11-11-2017, 02:30 PM   #6
northNH
northNH's Avatar
PM received; turns out ashtray is later style '68-, could switch handles...
Offer still stands.
Exactly where to?
Old 11-11-2017, 07:50 PM   #7
ZyreX
ZyreX's Avatar
Yes, I'll just try and switch the handles
Sending address in PM.
edit: I'll keep you updated how everything turns out ;) Looking forward to reassembling it. Will be a showcase thread then i reckon.
Old 11-14-2017, 05:01 PM   #8
northNH
northNH's Avatar
Ashtray on it's way today...
I wonder, after travelling ~3500 miles here ~50 years ago in the dashboard of an Amazon, and now ~3500 miles there in a box to Norway, how far from where it first saw life in Sweden will it end up being?
Best, Michael
