Old 11-09-2017, 07:07 PM   #1
AlaskanPrincess
Question Need Power Steering Fluid for 1993 240
Ok, puh-leeze be patient ...and tolerant. I'm desperate - fluid level is low ...
1993 VOLVO 240 S/W, non-turbo, A/T
I looked in owner manual for specs on P/S fluid, which says
"Fluid type: ATF."
I've also seen comments to absolutely NOT use P/S fluid.
The ATF specified is "Type F"
O'Reilly's: tried to sell me P/S fluid, then sold me 'O'Reilly's ATF + 4'
full synthetic, marked for Chrysler, Dodge, Plymouth, Jeep and SOME
Mitsubishis and Hondas.'
Auto Zone: sold me STP ATF, Type F, marked 'for Ford pre-1981.'
Note: I don't have access to VOLVO Brand ATF locally.
Is it SAFE for me to use the STP ATF?? Or do I need to buy another
brand??? If so, what??
AlaskanPrincess is offline   Reply With Quote
Old 11-09-2017, 07:14 PM   #2
Yes type F is the old school 'Ford' ATF without friction modifiers, I would use that if possible, but it probably doesn't matter if you use the later Dex - Merc stuff since there's no clutch packs in your PS pump.
Old 11-09-2017, 07:35 PM   #3
AlaskanPrincess
Thumbs up Thank you
Once again - big thank you for such a quick reply!
Old 11-09-2017, 09:53 PM   #4
lummert
lummert's Avatar
Type FA replaced Type F.
Old 11-10-2017, 01:12 PM   #5
Any of that **** will work.
Old 11-10-2017, 01:32 PM   #6
freevolvos
being a Saginaw pump i used regular dextron/mercron
Old 11-11-2017, 10:41 PM   #7
504
below the surface
Type F seems to be getting more scarce. My nearby parts store stopped carrying it so now I have to get it from Grainger.
504 is offline   Reply With Quote
Old 11-12-2017, 02:13 AM   #8
Brick15
Brick15's Avatar
I use what goes in my auto trans Mobil 1 ATF
Brick15 is offline   Reply With Quote
Old 11-13-2017, 10:21 AM   #9
Clear power steering fluid is the same as ARC.
The only time not to use ATF or power steer fluid, that I can think of, is on the modern German cars that take hydraulic fluid for power steering. CHF11S. $$.
Old 11-13-2017, 08:53 PM   #10
photoman327
photoman327's Avatar
I have had a few racks develop leaks with dextron.. a buddy that operated a shop for 30 years has told me more than once not to use dextron but power steering fluid. Did not know a four type F
Old 11-20-2017, 02:00 PM   #11
sjulier
This is a Saginaw pump so just about any fluid will work. I use Ford Mercon V ATF/Power Steering fluid in one car and Mobil 1 ATF in the other. I cannot tell any difference between the two fluids. Both have inline Wix filters in the return line. I do a drain and fill of the pump reservoir every 5k when I change the oil. It's less expensive than changing the steering rack. Ask me how I know. Per David Samuels aka The Wagonmeister: "Clean fluid is the number one concern in a hydraulic system."
Sam
sjulier is offline   Reply With Quote
Old 11-20-2017, 02:25 PM   #12
Pro Sneaker Peddler
Sam
The pumps don't care. You will be blowing out rack seals with power steering fluid. Any regular AC Delco spec ATF will work.
Old 11-20-2017, 04:25 PM   #13
sjulier
Harland, I ran a 1989 740 for 336,000 miles on Valvoline PS fluid in the rack. 5k drain and fills. Never an issue. So I'm not sure where your getting this info.
Sam
Old 11-20-2017, 04:33 PM   #14
JohnMc
JohnMc's Avatar
Sam
Wait, wut?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-20-2017, 04:41 PM   #15
sjulier
Wait, wut?
PS reservoir was drained and filled every 5k when the oil was changed.
Sam
Old 11-20-2017, 04:43 PM   #16
JohnMc
JohnMc's Avatar
Where did you get the idea that the PS fluid needs to be changed every 5,000 miles?
Old 11-20-2017, 05:22 PM   #17
John V, outside agitator
Don't ask.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 11-20-2017, 05:29 PM   #18
Pro Sneaker Peddler
Sam
Who's Harland?
http://pdfstream.manualsonline.com/d...d304e0c218.pdf
Page 188/204
Your Valvoline experience is one data point contradicting hundreds of others using a multitude of different PS fluid compounds. That's great that yours works. In general, for cars that aren't a 1989 Volvo 740 that has Valvoline flushed every 5000 miles, PS fluid is not a good idea.
Moreover, if you do the math, 1 qt of fluid every 5000 miles over 335+ thousand miles equates $335 in today's money. Figure that every fluid flush takes 45 minutes, that means that over the life of the vehicle, you spent $335 in fluid, plus 50 hours of your time doing flushes. Dunno about you, but I'd rather get a quality rebuilt Jorgen Automotive rack for about $250, and spend 2 hours installing that. I would have worked 48 less hours and spent $80 less.
Either way, your argument loses.
Old 11-20-2017, 06:04 PM   #19
photoman327
Sam
What is the part number of the wix filter?
Old 11-20-2017, 06:27 PM   #20
sjulier
[QUOTE=Harlard;5708813]Who's Harland?
Page 188/204
Either way, your argument loses.[/QUOTE
Harlard,
Your point is well taken. I use PS fluid now on my 93 240 Classics. I can't install a Jorgensen rack on my own so I'll have to pay someone else. Which is why I drain and fill at each oil change. The Mityvac sucks the fluid out in about 20 seconds, the fill takes a bit longer. The fill is usually 1/2 quart or $2.50. I do this while the oil is draining. There's really no wasted time.
Thats just my experience which I realize is one data point. I have never seen the 940 manual which I appreciate you attaching.
Sam
Old 11-20-2017, 06:36 PM   #21
sjulier
Don't ask.
I was young then. Now I'm wise like so many on this site.
Sam
Old 11-20-2017, 06:38 PM   #22
sjulier
58964
