Old 11-10-2017, 11:36 AM   #1
Ryan_R
Default AW-7X flexplates
Quick question:
Do AW-70/71's use a different flexplate depending on whether there's a lock-up converter or not? The lock-up and non- converters look very different in terms of how they mate to the flexplate, and the internets are showing me two different looking flexplates: one that's flat, and one that has a bit of a dish in it. VIDA is ambiguous.
The goal is to put the AW-70 from an '89 240 into a '91 Regina 740, so using the 240's Bosch flexplate is a no go.
Thanks!
-Ryan
Athens, OH
1987 245
1989 245 GL
1991 745 --Dog Waggin' 2.0
1995 945T -- Mildly modded
2011 XC90 3.2L AWD
https://people.ohio.edu/ridgely/e-code.htm
Ryan_R is offline   Reply With Quote
Old 11-10-2017, 01:55 PM   #2
Broke4speed
Broke4speed's Avatar
This may not be exactly what you asked, but I am currently using a flexplate from a BW55 on my B21, with an AW-71L. The BW55 was a three-speed non-lockup box, and the lockup converter bolted right up to it without issue. I'd assume it would be the same for any AW-non-lockup box to lockup.
1984 B21T (formerly A), AW71(minus L).
Old 11-10-2017, 02:59 PM   #3
jerryc
jerryc's Avatar
I put a lockup trans in my 95 940T using the existing flexplate, works fine.
I am 99% sure that the difference is the Regina plate has a different number of notches for the cps.
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 11-10-2017, 04:02 PM   #4
2manyturbos
^^ This.
Old 11-10-2017, 04:09 PM   #5
gsellstr
gsellstr's Avatar
Originally Posted by 2manyturbos View Post
^^ This.
^^This.
RIP
Mark Baldwin aka blue850t5 7/19/18
Nick Fengler aka fengler 8/6/18
74 144 B20
90 745Ti
Old 11-10-2017, 04:39 PM   #6
Ryan_R
Thanks all!
I just got a little wigged out that I wasn't going to be able to get an engine from one 240, a trans from a different 240, and Regina flex plate to play nice.
FWIW, I've the Regina flex plate on a B234 right now, and the Regina and 1990 B234 flex plates are identical aside from the CPS notch count. Both are flat as a pancake with little notches cut out for the four TC mounting bosses. There seems to be a 2nd style LH flex plate for the non-lock-ups. Good to hear that they're interchangeable.
Thanks again!
-Ryan
