Old 11-10-2017, 06:46 PM   #1
impolvo
Is always busy
impolvo's Avatar
Default 92 740 Regina stumbles at acceleration
92 740 regina stumbles at acceleration from idle
Once revs are up or while driving it has no issues or power loss noted
But starting out from idle the revs go up and down till enough speed is reached
Car has around 500k
Daily driver , automatic
Good cool, wires , plugs , distributor
Iac works temp sensor replaced with known good spare
Suppression relay good
Thinking low fuel pressure ?
Fpr has been replaced so maybe Fuel pump is dying ?
Had idle issues a year ago so I replaced the iac cleaned and adjusted throttle body and tps
my feedback: http://forums.turbobricks.com/showthread.php?t=221335
Originally Posted by Stephen View Post
Thats why you get a mans car... A 740
Originally Posted by rancidponymilk View Post
You people keep crushing them, you're going to run out eventually.
impolvo is offline   Reply With Quote
Old 11-10-2017, 08:28 PM   #2
impolvo
Is always busy
impolvo's Avatar
I'll replace fuel filter as it's never been done
At least not since I've had it
Old 11-10-2017, 10:02 PM   #3
kzoc
GM coil is known to go bad on these, leading to weak spark.
Volvo side: 84 242Ti
VAG side: 97 Jett TDI, 02 B5.5 Variant, 09 JSW TDI (Crushed!)
kzoc is offline   Reply With Quote
Old 11-10-2017, 11:02 PM   #4
sbabbs
sbabbs's Avatar
But yeah the fuel pumps, in tank only, also known to cause this same problem.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 544K MILES
Old 11-11-2017, 12:11 AM   #5
impolvo
Is always busy
impolvo's Avatar
I replaced it with known good unit
Old 11-11-2017, 12:12 AM   #6
impolvo
Is always busy
impolvo's Avatar
I'll do filter since I have one then pump if it doesn't clear up
Will post results
Old 11-11-2017, 05:54 PM   #7
impolvo
Is always busy
impolvo's Avatar
Changed filter and fixed the issue
So no idea if it is weak pump and partially plugged filter or just plugged filter
Either way fixed
