Old 11-11-2017, 09:16 PM   #1
Axd3nt
Default Volvo 240 Brake Master Cylinder question
So I have replaced the brakes and rebuilt the calipers. I flushed the system and still experience the same sensation in the brake pedal. It will start firm, as if stopping, sits for a second, but slowly sinks maybe 1/4 ways to the floor, but never to the floor. I suspect the master cylinder seal is bad.
Now, would a master cylinder ever cause a CEL to come on?
And is there a trick to taking out the reservoir as not to snap the plastic on the MC?
Axd3nt is offline   Reply With Quote
Old 11-11-2017, 10:51 PM   #2
freevolvos
sounds like a bad m.c. i don't know how it would cause a c.e.l. not sure on separating the plastic
Old 11-11-2017, 10:55 PM   #3
A new ATE master cylinder will come with a new reservoir already installed.
If it's been leaking for a while it may have softened and ruined the brake booster seal.
Old 11-14-2017, 08:49 PM   #4
Axd3nt
Good call. I'd say it's been leaking for approximately 6 months (2000 miles). Might be better to do the whole shebang.
Old 11-15-2017, 11:33 AM   #5
Pull it off first and take a look, good cheap boosters are hard to find now unless you have good junkyards nearby.
Or post in wanted and pay your ride I guess...
Old 11-15-2017, 11:41 AM   #6
nel621
Maybe just a bad check valve? Cheaper than a booster just to try.
Old 11-15-2017, 11:52 AM   #7
Ya give it the suck / blow test when you have it out obviously...
Old 11-20-2017, 01:27 PM   #8
sjulier
ABS or non-ABS?
sjulier is offline   Reply With Quote
