Old 11-12-2017, 01:15 PM   #1
V70XC
Default Possible ABS module failure?
Occasionally while driving, and sometimes on startup, my odometer and trip read ----.-/------, my speedometer drops to zero and my brake and ABS lights turn on.
V70XC is offline   Reply With Quote
Old 11-16-2017, 11:36 AM   #2
Janspeed
please mention the model and year of production. It increases your chance of getting a useful answer.
Old 11-16-2017, 11:40 AM   #3
JohnMc
JohnMc's Avatar
If it's the V70XC, I'd have no idea. If it's a late model RWD 240/740/940, then it's likely the speed sensor in the rear axle, that runs both the speedo/odo and one of the 3 circuits in the ABS system. Bad sensors on the diff cover, or bad wiring to it, would give you those symptoms.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-18-2017, 10:30 PM   #4
ovlov760
ovlov760's Avatar
TRACS module issues are very common in P80 Volvo's. Easiest option is to buy a rebuilt unit. Hardest option is to cut open your existing box and reflow the solder. You'll have to seal the box up watertight if you go that route.
2006 V70R GT
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 11-29-2017, 03:25 PM   #5
emem1160
Sounds like this is a p80. The ABS module is easily replaced with a junkyard module or one from ebay. Make sure you get the correct one for yourself (TRAC, ect).
An ABS sensor problem on each wheel can mimic this also.
emem1160 is offline   Reply With Quote
