Old 05-08-2006, 05:40 AM   #1
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Default Oxygen Sensors - Universal O Sensor
Just creating a master list of compatible inexpensive O sensors that will work in our cars, please post any info/experience you may have and I'll update the list. Also include any good sources that you know of.
Note: any non "direct fit" entry followed by an ** indicates this has been done and known to work normally, where as "direct fit" is assumed to work.
240:
→11028 Bosch 1 wire Direct fit (36$ at fcpgroton)
→11027 Bosch 1 wire Universal (under 19$ at fcpgroton.com)**
740T/760T:
→13913 Bosch 3 wire Universal (under 40$ at Autozone)**
→13942 Bosch 3 wire (92 V8 Mustang, 8.5" long wire, 39$ @ Autozone)
→13953 Bosch 3 wire (92 V8 Mustang, 16.5" long wire, 40$ @ Autozone)**
740NA (LH):
740NA (Regina):
→25003 NGK/NTK
can be obtained from NTK web site or www.oxygensensors.com or sparkplugs.com
940T:
1991 through 3/31/1993
→13957 Bosch 3 wire Direct fit
→15735 Bosch 3 wire Universal **
4/1/1993 +
→13381 Bosch 3 wire Direct fit (# 0 258 003 381, Volvo# 9135794)
→13913 Bosch 3 wire Universal (under 40$ at Autozone) **
4/1/1993 + with California emissions (EGR)
→13376 Bosch 3 wire Direct fit (bosch# 0 258 003 376)
→13942 Bosch 3 wire Universal (92 V8 Mustang, 8.5" long wire, 39$ @ Autozone)
→13953 Bosch 3 wire Universal (92 V8 Mustang, 16.5" long wire, 40$ @ Autozone)
940NA (LH):
→13034 Bosch 3 wire Direct fit
940NA (LH)+ with California emissions (EGR):
940NA (Regina):
→25003 NGK/NTK
940SE:
See 940T above.
960NA:
→13119 Bosch 3 wire Direct fit ('92-'95)
→15098 Bosch 4 wire ('95-'98 before Cat)
→15099 Bosch 4 wire ('96-'98 after Cat)
Other:
→15727 Bosch 4 wire
Not sure what this would specifically be applicable to, but should work in place of any car that specifies the 15735, though you may have to hook up the 4th wire (ground).
Three Fat Tigers is offline   Reply With Quote
Old 05-08-2006, 06:14 AM   #2
mojam
Good one man.. that'll be usefull... kudos
My Car's Blog
mojam is offline   Reply With Quote
Old 05-08-2006, 10:43 AM   #3
Justin Volvo
Slow Rider
Justin Volvo's Avatar
Do you know if there is any difference between these sensors aside from the connectors? I see the EGR car has a different model listed than the same year non-EGR car, for instance. (Actually I have the exhaust from a '94 940T with EGR and am wondering what's up with the O2 sensor)
Justin Volvo is offline   Reply With Quote
Old 05-08-2006, 11:13 AM   #4
Sinbad the Sailor
Master Destructor
Sinbad the Sailor's Avatar
Do all 02 sensors have the same thread, or is that the difference between direct fit and universal. Nice work. I was wondering about this when I was ordering from FCP
'85 244 DL - R.I.P
'82 244 TIC - MS/13c/Crane Hi-6/Jacobs Coil/Full 3 in exh/3 Row Nissens/E-Fan
'63 p1800 - Gone to a better place
Originally Posted by tedium
The standard rule of engineering: If you make something idiot-proof, they will just make better idiots.
More often stated: Nothing is foolproof to a sufficiently talented fool.
tim
Sinbad the Sailor is offline   Reply With Quote
Old 05-08-2006, 12:42 PM   #5
Can play the blues
Default O2 sensors
When I was at Autozone they said the universal listing for a 1993 245 from Bosch is 15737. I never tried it though because it was expensive. I've used the 15727 four wire on two LH2.4 240 series. My old 1989 and now my 1993 wagon. It works very well. The instruction sheet reads that you can leave the extra ground wire off but I run it to the valve cover.
The car runs great with the 15727 sensor. It was $60 at the Autozone in Burlington, NJ.
Prior to this I was running an NTK three wire universal on my wagon and after about six months it started setting the bad O2 sensor signal. Maybe I got a bad one but after feeling how much better my car runs with the 15727 I don't think the NTK universal is compatible with LH2.4.
Thanks for the list!
Old 05-08-2006, 07:37 PM   #6
arekaye
arekaye's Avatar
I can't believe I paid $120 for mine at autozone.
arekaye is offline   Reply With Quote
Old 05-08-2006, 10:59 PM   #7
seb8191
seb8191's Avatar
what about the 3 wire 02 sensor in a 91 244? for the 240, u have one wire
seb8191 is offline   Reply With Quote
Old 05-08-2006, 11:12 PM   #8
boosted12a
weapon of mass detonation
boosted12a's Avatar
how about us v6 guys?
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
Old 05-08-2006, 11:16 PM   #9
boosted12a
boosted12a's Avatar
ok, did some quick checking, looks like the universal for the 84-91 turbo 4 is the same for the 87-90 b280f, acording to fcp grotten, so.......
Old 05-08-2006, 11:37 PM   #10
own6volvos
He who controls the Spice
own6volvos's Avatar
ATP sells an awesome "universal" thing. Basically a normal sensor, you chop off the cable end. 39 bucks
http://www.atpturbo.com/Merchant2/me...egory_Code=SNS
The heated one is 4 wire, all you do is connect one to the chassis, as it does not ground through the exhaust tubing.
own6volvos is offline   Reply With Quote
Old 05-08-2006, 11:41 PM   #11
swedefiend
I've been using the bosch single wire from a Ford application for several years now (~$9.00)
Old 05-08-2006, 11:43 PM   #12
swedefiend
I have a part number for the universal wideband (5 wire) sensor on my HD somewhere. I'll post it up tomorrow.
It's about $35 IIRC
I think it fits on the v70 and s60.
Old 05-09-2006, 04:37 PM   #13
Three Fat Tigers
Ok I physically looked at the following sensors today:
→13913 Bosch 3 wire Universal (38$ at Autozone)**
→15727 Bosch 4 wire Universal (60$ @ Autozone)
They all appear to be the same sensor, however each sensor was stamped with a different number for the last three digits, all start with 0 258 003 and end with the last three numbers of the short part number.
I'm confident the 3 wire types are in fact all the same sensor with different wire lengths. The 15727 4 wire had the longest wire by a notable amount, while the 13913 had the shortest wire, which was just a little shorter than the 13942.
I went home with the cheapest which was the 13913 for 38$.
Old 05-09-2006, 06:21 PM   #14
765tiME
765tiME's Avatar
I too stocked up on the 13913s a few years ago, originally for my Audi. I bought 3 of them for $30 a piece at an Audi parts site. They were advertized as a cheap cut and splice option for a sensor.
765tiME is offline   Reply With Quote
Old 05-09-2006, 07:41 PM   #15
ShadowofBob
Revived...
ShadowofBob's Avatar
Thanks for the list. I didn't know that turbos and NA had different sensors. Wonder if that is going to affect my +T when I have to get it smogged in a month. If I buy a new one should I base it on the ECU and what year/model car it is from?
Kinda a weird combination on my car. 1993 940 Turbo ECU w/ Cali 1995 EGR valve.
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
Old 05-09-2006, 08:15 PM   #16
swedefiend
I am only aware of three different types of narrow-band oxygen sensors:
1. Single wire, non-heated
2. Three wire, heated (preheating allows for better O2 control during startup)
3. Four wire heated with reference ground
These sensors all produce 0-1v signals proportional to the AFR in the exhaust. However, the narrow band sensors have a very narrow range of accuracy (hence the name.)
There are other types of O2 sensors out there, but none were ever OEM on a Redblock AFAIK.
So, actually the single wire will do the same job as the others, but on newer ECU's a DTC may be set if the other wires are not used (however, there are very simple cicruits available that trick the ECU into "seeing" the other wires usually connected )
Old 05-09-2006, 08:27 PM   #17
swedefiend
Unknown application/ Universal (good for all cars needing 5 wire wideband sensors)
→15738 Bosch 5 wire Universal (~$60 on Ebay, must be crimped onto factory connector pigtail)
Old 11-13-2017, 07:40 PM   #18
maxitoman007
Couldn't you just use any 3 wire o2 sensor and just solder the leads? As long as it's a Titania style? Wouldn't they all do the same thing?
maxitoman007 is offline   Reply With Quote
