A
Anonymous
Guest
Hey guys, I'm not sure what to do here..........
THE PROBLEM:
Front Rotors were badly warped at 204,610 miles causing front wheels to shake......
Replaced front Rotors w/premium Brembo replacements, replaced pads with Albany brake pads I picked up at Autozone that were only ($19.95) since the PBR replacements that came were not the right ones although I specified Bendix Calipers. I think the Albany pads were like semi-metallic or something.
I had Big O' Tires do the work because they were close and I didn't have time.
The brakes were fine and everything until 214,000 miles where the front end began to shake badly again........
All front end Steering and Suspension components (Tie Rods, Ends, Suspension Control Arm Bushings) were replaced prior to all of this so I knew it's not that..........
I had the rear Rotors replaced and front Rotors turned, the Brakes were fine after, just squeaked a little, no big deal.
Now, a little over 220,000 miles the front end is starting to shake again! There is an annoying rubbing noise when slightly letting off the brake pedal sometimes and they squeak just when driving, they are squeaking badly!
I do not ride my Brakes and I even sometimes downshift to slow down when driving fast, then use the Brakes to save excessive brake wear!
THE QUESTION:
Is this becasue these Albany pads just suck and are destroying my Brembo Rotors or could I have some defective Rotors????? Is there anything else I should check into as to why my Rotors are warping so quickly????
I'm thinking about either just replacing the front Brembo Rotors with ATE vented rotors with PBR pads or should I just get the Rotors turned again and the pads replaced with something better.......?
THE PROBLEM:
THE QUESTION:
