Tomslide50
- Mar 13, 2007
No. The narrow band lambda sensor doesn?t have a clue about AFR, only lambda.
The ECU will tune to lambda=1 on idle regardless of the fuel used, and lambda=1 for E85 is 9.8.
I'm sorry. I know this has been covered and I'm not trying to be difficult here(I appreciate the write up!), but I don't understand how the O2 sensor can compensate. The ecu doesn't tune for lambda, it tunes for 450mv. O2 sensors use the difference in outside air and exhaust air oxygen content and output a signal voltage based on that. Oxygen content increases with AFR. It does not spike in any way at lambda. If the amount of flow remains the same, and the fuel content increases, the O2 content will decrease. The ECU will not change it's desired reading of 450mv. Maybe I'm missing something here. I have to confess I didn't read all 6 pages. Thanks in advance for any clarification you can give me.
